586,071 active members*
3,912 visitors online*
Results 1 to 8 of 8
    Oct 2006
    14
    Dahlih MCV 1020 Fanuc 10m
    Does anyone have a Dahlih MCV 1020 3 axis mill with a Fanuc 10m control? I need to get the pmc parameters for it. Fanuc had to change the master pcb board and now I only have the use of 15 tools instead of 20. I guess they didn't save everything or save it right. Fanuc said to get the parametrs from Dahlih, but this is proving to be a very slow process. If someone could send me the pmc file I would greatly appreciate it.
    Thanks, jamie [email protected]
    If it ain't broke, give me a secound!
    Aug 2007
    6
    I had a similar problem and I fixed it by going to the data table in the nc/pc selection and filling out all the tool numbers I am not sure if this is the same issue but is worth a look I also have a dahlih so I could down load the parameters for you
    Oct 2006
    14
    CNC Programmer/Operater
    Thanks but it's fixed. There is a parameter to set for 20 tools, I have it somewhere but off hand I don't know what it was.
    Oct 2017
    5
    Re: Dahlih MCV 1020 Fanuc 10m
    Hi, I am really hoping someone here can help me. We have a Dahlih MCV 760 with Fanuc 10m controller. The machine is very old and has lost it's PMC data. Does someone perhaps have the data for me?
    I would really appreciate it!
    Aug 2007
    6
    Quote Originally Posted by Dasten100 View Post
    I had a Dahlih 610 which I just sold I will see if I can download the PMC data from it give me a day or two
    Oct 2017
    5
    Quote Originally Posted by davestewart53 View Post
    Thank you so much, DaveStewart! Much appreciated.
    Aug 2007
    6
    I have downloaded the PMC and all the data files in two separate files you can email me at [email protected] and I will send them to you
    Regards
    Dave
    Aug 2007
    6
    I have never tried this so I am not sure if this will work , I have uploaded the two files let me know if you get them
    Thks
    Dave
  1. Replies: 16
    Last Post: 01-10-2014, 09:24 PM
  2. Mode switch for Fanuc 10m on a Dahlih 1020mcv
    By davestewart53 in forum Want To Buy...Need help!
    Last Post: 03-11-2010, 04:19 PM
  3. Fanuc 10M on Dahlih MCV 760.
    By Jakes in forum Fanuc
    Last Post: 01-28-2009, 10:06 PM
  4. Dahlih MCV 1020 Fanuc 10m
    By burbankbrewer in forum Community Club House
    Last Post: 11-15-2006, 05:44 PM
