Re: Grounding....how important is it?
Originally Posted by
alan_3301
Unless you have wiring problems, your 110V ground should be perfectly adequate.
In my limited knowledge, the purpose of the grounding wire is to provide a path to ground to trip the breaker in the event of a short circuit.
This is for safety, to prevent shocks.
I would take the separate grounding lug as a notice to inspect the wiring of the whole device.
The purpose of a ground wire is sensible in China where thay have 2-wire instalations.
You only need to check if all internal components (PSU, mainboard, laser PSU) are grounded as well as machine body.
CNC lasers, constructions, service
