Now that I have a working ATC, I want to automate as many operations as possible. That means, in part, ditching my auto-reversing tapping heads (one Chinese, one Procunier, and one Tapmatic), and switching to tension/compression heads. The easy answer would be to buy several, but at ~$175 each, thats a major investment. They're simple devices, so I figured: Why not make my own! Here is my design:
The tap is held in an ER20 collet chuck that will be made by sacrificing one of my many non-AT-friendly Chinese TTS-knockoff ER20 chucks. The top "cap" is made from 1.5" 303 SS round, with the 3/4" shank pressed-in. The outer housing is 1.5" x 1/16" wall 4140 tube, pressed into the top cap. The lower cap, at least initially, will be 6061, to make it easier to broach the 1/2" hex hole for the output shaft. The shaft allows the ER20 chuck to move up and down ~+/-3.8", while springs (not shown) between the housing end caps and the washers in the center of the hex shaft provide the tension/compression feature. the top of the hex shaft is turned down to 1/2" round, and rides in a bushing in the top cap, to better center the hex shaft, and provide lateral support. The whole thing costs about $10-20 in materials, and is dead-simple to make.
Here is the first part - the shank, top cap, and housing, made in about 90 minutes this AM.
Once the prototype is done, I should be able to knock out 3-4 more in an afternoon, and each of my most-commonly used taps can then be permanently mounted in their own tapping heads!
Regards,
Ray L.
