Originally Posted by
nessie_bg
Hello,
I am using MACH3 Mill for my glass cutting machine.
I define a cutting speed of 70 000 when importing the dxf file. While executing the G-code, MACH 3 reaches almost 30 000. The defined speed for the motors is also 70 000. When I use the manual mode of the JOG X++ and JOG Y emulation, I do reach the speed of 70 000. But my problem is that I can't reach that speed if the G-code is executing it.
I'll appreciate any suggestions and ideas. And if someone is willing to run it on their machine and let me know if they are gettin the full speed.
Here is the G-code (t1.tap)
(File t1 )
(Sunday, November 12, 2006)
G90G80G49
G0 Z1.0000
G90.1
S1000
G0 Z1.0000
G0 X0.0000 Y0.0000
M3
F70.000G1 Z0.0000
F50000.000G1 X3500.0000 Y0.0000
G1 X3500.0000 Y2500.0000
G1 X0.0000 Y2500.0000
G1 X0.0000 Y0.0000
S1000
G0 Z1.0000
G0 X400.0000 Y0.0000
M3
F70.000G1 Z0.0000
F50000.000G1 X400.0000 Y2500.0000
G0 Z1.0000
G0 X400.0000 Y2400.0000
F70.000G1 Z0.0000
F50000.000G1 X1200.0000 Y2400.0000
G1 X2000.0000 Y2400.0000
G0 Z1.0000
G0 X2000.0000 Y2500.0000
F70.000G1 Z0.0000
F50000.000G1 X2000.0000 Y0.0000
G0 Z1.0000
G0 X1200.0000 Y0.0000
F70.000G1 Z0.0000
F50000.000G1 X1200.0000 Y2500.0000
G0 Z1.0000
F70.000G1 Z0.0000
F50000.000G1 X0.0000 Y2400.0000
G0 Z1.0000
G0 X0.0000 Y1800.0000
F70.000G1 Z0.0000
F50000.000G1 X400.0000 Y1800.0000
G0 Z1.0000
G0 X400.0000 Y1200.0000
F70.000G1 Z0.0000
F50000.000G1 X1200.0000 Y1200.0000
G1 X2000.0000 Y1200.0000
G0 Z1.0000
F70.000G1 Z0.0000
F50000.000G1 X0.0000 Y1200.0000
G0 Z1.0000
G0 X0.0000 Y600.0000
F70.000G1 Z0.0000
F50000.000G1 X400.0000 Y600.0000
M5
G0 Z1.0000
G0 X0 Y0
M5M30
Nessie
Nessie if you will look at the bold highlight in your gcode you will see what Gerry was talking about. You typed 70 000 in your description but your gcode
shows f70.000. Are you wanting 70 mm per minute? The code that is bold and larger shows you are asking for a feed speed of 50,000mm per minute. You have quite a difference in your requested feed range.
Your settings will very much affect how your machine behaves plus the machine mechanics will also affect it. Is your Mach set to exact stop or cv. Most gcodes will never reach or maintain max speeds if the cuts are short, though it does not appear that would be your problem.
Your requested 70 000 is over 2700 inches per minute.
Mike
No greater love can a man have than this, that he give his life for a friend.
