586,106 active members*
2,966 visitors online*
Results 1 to 3 of 3
    Oct 2005
    1145
    Tool Life Management
    Are any of yous guys interested in tool life management ???
    Just a thought , (;-) TP
    Aug 2020
    106
    Re: Tool Life Management
    I would be very interested. I quite honestly look for chips and watch/listen to the way it cuts. Seems as if there is a better way. I thought I came across somewhere in PP where there is some sort of way to do this? Maybe it was Fusion 360 which wouldn't work as I don't always machine using Fusion created files. What are you speaking of?
    Oct 2005
    1145
    A simple TM scheme just keeps track of time on each tool and when it gets to the time limit it warns you that the tool is at its time limit. It also gets more complicated from there. Advanced TM will change out a worn tool to another of the same tool in the Tool changer.
    Advanced also lets you assign what parameter you use for teh limit such as time,cutting inches, holes drilled, etc.
    Just a simple time based TM would be nice for PathPilot. You would have to expand the Tool table to make it work.
    (;-) TP
  1. Replies: 3
    Last Post: 03-14-2024, 03:56 PM
  2. Tool Life Management
    By oshuab in forum Okuma
    Last Post: 07-20-2016, 08:31 AM
  3. Tool Life Management
    By moaker2 in forum Fanuc
    Last Post: 05-17-2016, 07:24 PM
  4. Tool Life Management
    By pp-TG in forum Fanuc
    Last Post: 03-15-2016, 01:15 AM
  5. Tool Life Management on MSG-500
    By fordav11 in forum Fanuc
    Last Post: 09-14-2011, 09:01 AM
