586,470 active members*
3,391 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Home Made Cheap Mini Lathe Slide CNC
    May 2015
    67
    Angry Home Made Cheap Mini Lathe Slide CNC
    Parts and Tools:
    12 pcs SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
    2pcs 500 mm 20 mm Linear Rails
    1 Pcs 160 mm x 160 mm x 12 mm Aluminium Alloy 6061
    1 Pcs 105 mm x 160 mm x 12 mm Aluminium Alloy 6061
    1 Pcs 60 mm x 160 mm x 12 mm Aluminium Alloy 6061
    2 Pcs 60 mm x 160 mm x 12 mm Aluminium Alloy 6061
    2 Pcs 80 mm x 110 mm x 12 mm Aluminium Alloy 6061
    Bearing 40 mm / 17 mm
    Lathe Chuck 80 mm 2 pcs, Head Chuk Drill,
    More Homemade Lathe DIY Mill Miling CNC Router here:
    May 2015
    67
    Re: Home Made Cheap Mini Lathe Slide CNC
    May 2015
    67
    May 2015
    67
    May 2015
    67
  1. My cheap Home made CNC router
    By 7705nick in forum DIY CNC Router Table Machines
    Last Post: 06-28-2011, 05:14 PM
  2. Mini Lathe Cross Slide Ballscrew Solutions
    By snoopy27 in forum Mini Lathe
    Last Post: 08-08-2009, 09:25 PM
  3. Home made cross slide power feed for small lathe
    By monte55 in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2007, 08:30 PM
  4. Cheap home made Touch Probe.
    By mikegasman in forum Digitizing and Laser Digitizing
    Last Post: 11-16-2007, 02:18 AM
