586,036 active members*
3,790 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > older yang mill doesnt like g93 inverse time feed
    Jan 2015
    17
    for 4th axis work, it alarms, problem is its a twisty part so when I take off the g93 and run the feed at 200.imp when theres a straight none twisting move its way too fast of a feed
    and a ton of code
    any idea of what code this machine need
    fanuc control
    O-MD
    Dec 2009
    953
    Re: older yang mill doesnt like g93 inverse time feed
    i think you need to sit down and take a deep breath and try to explain once again what is your problem because for me is no sense at all.
    Jan 2015
    17
    could be you just don't understand English so well being in/possibly from Romania?
    yang mill
    fanuc control
    alarms when using g93 command for 4 axis simultaneous movement feed command
    any substitute command for this older machine/control?
    thoughts or ideas
    2932
    It would help if you told us what alarm you are getting. My guess is the option isn't turned on.
    Jan 2015
    17
    im finding more out each time I go to that place, its a side gig for me
    I found out that this machine must have the tool change code like this
    M6 T1
    I found out that it must have the code for the axis unclamp in the program,
    M11
    neither of these ive ran into before, and before it wasn't moving but I bet that was because of the lack of the m11 code, and im going to give it another go with the g93 in there today
    but if I remember it may have given me a p/s alarm, but ive tried so many things so far I cant remember, and think im just about to crack this case and get to making parts
  1. (5 Axis) proper inverse time feed in BobCAM Post?
    By CWILLIS1477 in forum BobCad-Cam
    Last Post: 06-23-2015, 04:01 PM
  2. 4 and 5 axis post question (inverse time feed)
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-22-2013, 12:46 AM
  3. Inverse time
    By extanker59 in forum Haas Mills
    Last Post: 11-09-2011, 05:50 PM
  4. G93 Inverse time
    By DaveMCINC in forum Fanuc
    Last Post: 12-07-2009, 06:22 PM
  5. G93 Inverse Time Feed Mode
    By MarkT in forum Haas Mills
    Last Post: 01-18-2007, 07:28 PM
