Hey guys, I hope this will be the best place to put this thread as it is a build….sort of. I have exhausted all of the search terms I could figure out and decided it might just be best to make a thread.
I recently acquired a slightly used ESAB piecemaker 2. I say slightly because it was originally used in a school environment and shows very few cut marks in the table slats, basically the first three feet. The original software is intact and can move the torch, run a predetermined shape, etc. I have a mind boggling 50+ shapes at my disposal, it’s so 1999. I, of course, want to upgrade the software to Mach or better to run designs off my computer.
Looking in the boxes I noticed the X and Y are servo driven with encoder feedback straight back to the Vision CNC board. Should be easy enough to run Geckos and reroute encoders back to them. That should handle X and Y. The Z on this table is a DC torch lift motor, it operates as advertised I do believe. Looking at the schematics it has a torch height control card installed and has input from the plasma cutter for information. The schematics show how to wire in several of the mainstream cutters(Hypertherm, TD, etc.).
I will post the main page of the schematic showing the THC, but I am left with a few questions.
1. What is my best option for a BOB? Smoothstepper and card for I/O? USB or Ether SS?
2. Mach 3/4 , Sheetcam?
3. Can I use the THC already installed with this BOB?
4. Will the DC lift motor do the job? It is already in place. Or will I need to run a new Z and stepper?
5. I will eventually want to run a scribe as well, so I would like options down the road.
6. I would like to get it running with the ESAB cutter I got with the table for now but I already have options in place.
Thanks in advance on any help you can provide, Chris.
