586,082 active members*
3,703 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Move command works until velocity command issued
    Jun 2015
    10
    Hi, got all set up with a kflop and h2n servo drives.
    got tuned with full movement.
    if I set params and use move0=1000 I get perfect movement. As soon as I issue a moveatvel command or a vel0=10 command all movement stops until reset.
    Help?
    madprinter
    May 2006
    4045
    Re: Move command works until velocity command issued
    Hi madprinter,
    Are you running Version 4.33l ? If so this may be the issue:
    http://www.cnczone.com/forums/dynomo...ml#post1723336
    Otherwise could you include more details of exactly what you are doing?
    Regards
    TK
    http://dynomotion.com
  1. Air gun Off Command
    By nfrees114 in forum BobCad-Cam
    Last Post: 04-08-2014, 06:28 PM
  2. Fanuc OI does not move after M3 Command
    By kabdelwahid in forum Fanuc
    Last Post: 03-05-2014, 07:30 AM
  3. SV command
    By BFHammer in forum Fadal
    Last Post: 03-22-2013, 12:32 AM
  4. M6 Command only works one time now with new computer setup
    By jevs in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2013, 06:53 AM
