586,110 active members*
3,345 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Danfoss ISD401 Servo-drive dc motor
Results 1 to 1 of 1
    May 2015
    28
    Hello.
    I am building a CNC machine.
    Most of the mechanical parts are done. I planed to build a Medium duty CNC router machine that is capable to cut through aluminum and similar hardness metals.
    The usable dimentions are 1000 X 1000 X 450 mm on the X, Y, Z axis.
    Everything is going fine , except the servo drive conections..
    I have 3 ISD 401 servo drive dc motors from Danfoss. The problem is that the motor have integrated all the drive and encoders inside the housing, and I am wondering if there will be any compatibility problem to connect these motors to a breakout board.. The drives comunicate via Can-bus and talk IEC61131-3 language.
    I could nt find too many things about these motors on the internet neither with the manufacturer.
    Is there anyone that have the knowledge to help me find the best solution to connect these motors in my computer and be able to run it on a software that uses g-code?
    Thank you.. If there is any other information I can provide just ask..
    300 Vdc
    10 Nm Torque
    4.4 Amp.
    comunicate via can-bus. Has can high, can low, can vcc, and can ground pins + 4 pins for 300 Vdc and 24 vdc
    Talk IEC 61131-3
    http://www.cnczone.com/forums/attach...d=284856&stc=1
    http://www.cnczone.com/forums/attach...d=284858&stc=1
  1. Danfoss s1000 DC Motor speed controller - help needed!
    By HankMcSpank in forum Servo Motors / Drives
    Last Post: 06-29-2015, 08:16 PM
  2. Replies: 3
    Last Post: 02-11-2015, 06:07 AM
  3. Replies: 0
    Last Post: 10-21-2014, 09:29 PM
  4. Servo Drive AC + servo motor for car steering wheel simulator
    By yusukeand in forum Servo Motors / Drives
    Last Post: 01-10-2014, 09:06 AM
  5. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
