586,465 active members*
3,844 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Geckodrive G540 Multiaxis Step Drive
    Jul 2014
    7
    I Have two, fresh units with test result paperwork from Geckodrive. $190 plus shipping per each unit. ($100 savings)
    The G540 is a complete 4-axis system which plugs directly into your computer via the parallel port and to your motors through DB9 connectors.
    It contains four G250 drives, an integrated breakout board to control a router or plasma torch, and a hard anodized aluminum case.
    Four 10-Microstep motor drives
    0 to 3.5A rated phase current
    18VDC to 50VDC supply voltage
    Mid-band resonance compensation
    Auto standby current (70% current)
    Optoisolation on all LPT signal pins
    Two 1A at 0 to 50VDC rated outputs
    Four SPST to GND inputs (TTL)
    FAULT indicator LED,signal to PC
    POWER indicator LED
    I-SET resistor on motor connector
    TRIM adjust for motor smoothness
    Panel mount (5.7? by 2.4? hole dim.)
    Anodized aluminum package
    10kHz watchdog timer (charge pump)
    Optoisolated analog output for a VFD drive
    List Date: 6/29/2015
    For more info, click here to view the original listing: Geckodrive G540 Multiaxis Step Drive
    On Sale For: $207.14 + $10.00 Shipping
    Mobile friendly version: Geckodrive G540 Multiaxis Step Drive
    Go Mobile: Download the free Panjo iOS app now!
    Feb 2009
    1290
    Re: Geckodrive G540 Multiaxis Step Drive
    fresh = new?
    Thank You.
    Jul 2014
    7
    They were technically hooked up so they are technically not new. They are like new and I couldn't tell the difference.
  1. Replies: 2
    Last Post: 06-12-2014, 11:08 AM
  2. 3 Months, I Finally Got Mach3 to Talk to GeckoDrive G540
    By Darryl Hammonds in forum Mach Software (ArtSoft software)
    Last Post: 03-25-2013, 02:58 AM
  3. please help g540 geckodrive
    By phildunk in forum Gecko Drives
    Last Post: 03-10-2013, 01:09 AM
  4. Geckodrive G540 Four Axis Control Bulk Pricing
    By CoAMarcus in forum News Announcements
    Last Post: 01-24-2009, 03:13 AM
