Hi
After several days with reading and testing I realize I need help with the parameter settings for the VDF. I have a Sunfar E550 VDF and a water cooled 60.000 rpm, 1000Hz, 1,2KW China spindle. I do use the Csmio IP-S to control my cnc and the spindle. The software I use is Mach3 .
I did first run the spindle with the original settings in a few sec, I did stop before any error/warning, I understand now this could destroy the spindle. I do not know if the spindle is ok or not.
After playing around with all the F,s for a while I was able to run the spindle in a few sec on low rpm before the error Fu.03 jump in. Under my testing I did also get error Fu.01.
Are there any "forgotten" and/or wrong parameter settings?
My settings look like this:
F0.00 - 1 & 3 ( 1 when I use Mach3, 3 when using the pot.meter on the VDF )
F0.04 - 1000Hz
F0.05 - 10 sec
F0.06 - 10 sec
F0.12 - 1000Hz
F0.13 - 220V
F1.04 - 1000Hz
F1.06 - 0V
F1.07 - 10V
F1.18 - 1000Hz
I hope some can help me with the VDF settings. I am so close to end a 2 years work on a homemade cnc machine.
Steen
Sunfar E550 Manual:
