Re: 3 phase 360V electricity for CNC machine
It looks to me as though the machine has 3 phase terminal strip and the white is actually intended as ground, especially if the green wire on the block goes to enclosure chassis.
IF the machine IS wired for 3 ph and GND then there most likely is a 1phase transformer inside taken off of two phases(1ph) for the computer and control.
With H.V. 3ph and GND a neutral is seldom supplied or needed.
It would be ideal to see a schematic, they should have provided one?
Al.
Albert E.
