586,070 active members*
3,450 visitors online*
Thread: Crazy Z
    Sep 2011
    38
    Crazy Z
    PLEASE JOIN IN
    I have a Bridgeport series 1 converted with PMDX 126 , GECKO drives , ESS , Using the old stepper (superior) motors
    MACH3 BOBCAD 25
    Running on a rotary phase converter
    All seem well for 6 months then loose Z drive so i replace Replace Z DRIVE
    all works well for about ! month Then I loose Z drive again so i replace drive again These are 203 V GECKO (VAMPIRE) hard to kill
    Well here we go again
    I can swap the motor leads at the breakout board and prove the motor good
    all motors and cables test good on X,and Y
    Only Z has a problem and it is only when hooked up to BOB at Z output
    SOO I replace BOB same problem
    Soo i replace PMDX 126 same problem
    Soo i replace Z motor same problem
    sometimes the motor will run in 1 direction and that is minus if you tell it to go pos it shows pos on mach 3but still is turning neg direction
    could this be a mach issue
    PLEASE PLEASE join in with any thing you have to help with this
    Harry
    Oct 2006
    323
    Re: Crazy Z
    I would suggest writing or calling Gecko. The Vampires are hard to kill, but I believe dropping power to them while under load is like a stake in the heart. Everything else is like garlic, might trip or fault (make it mad), but not kill it. I would double and triple check the whole DC supply chain to ensure solid non-transient supply.
    Jun 2013
    1041
    Re: Crazy Z
    Have you tried replacing the z axis cables?
    Ben
  1. Am I crazy?
    By swaxolez in forum Joes CNC Model 2006
    Last Post: 01-31-2021, 02:24 AM
  2. Please Help! Going Crazy
    By Guitarflyer in forum Uncategorised WoodWorking Machines
    Last Post: 01-24-2014, 06:54 AM
  3. New crazy idea....
    By pete from TN in forum Benchtop Machines
    Last Post: 04-26-2008, 12:05 AM
  4. LPT crazy
    By Lu_ca in forum DNC Problems and Solutions
    Last Post: 04-06-2005, 12:17 AM
