586,089 active members*
3,915 visitors online*
IndustryArena Forum > CAM Software > MadCAM > profile clean up pass
    Dec 2012
    57
    What is a good way to toolpath a cleanup pass when profiling?
    For example imagine circle cut out of 0.75 inch thick MDF or plywood. I would normally select profiling and set the cutter to climb cut outside the line. I usually set a ramp of 10% which works ok. I usually select around a 0.15 depth cut for each pass. I usually do not leave a skin because I attach most of my work to the spoilboard with screw holes.
    My question is related to the problem of having a cut surface with the steps showing and I sometimes would like to have a full depth pass that is perhaps 0.01 inch offset inside to clean that up.
    Is there a way to do this without creating an offset line and using it for a full depth profiling pass?
    Mar 2004
    1661
    Re: profile clean up pass
    Yes.
    First path - whatever you use - set Stock to Leave to 0.01.
    Second finishing profile path set Stock to Leave to 0.00.
    Dec 2012
    57
    Thanks! And i assume i set step down for the full amount on the second profile path. I will do this.
    Ken
  1. Turn off profile finish pass
    By Forrest C in forum BobCad-Cam
    Last Post: 01-16-2014, 01:21 AM
  2. Replies: 1
    Last Post: 11-26-2013, 02:50 PM
  3. Cut 2D Profile pass
    By laserpilot in forum Vectric
    Last Post: 08-07-2012, 04:41 AM
  4. One clean up pass after threading…T32B
    By Captdave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-09-2009, 03:55 PM
  5. G71 rough boring - remove final profile pass
    By Busted in forum G-Code Programing
    Last Post: 01-19-2009, 07:08 PM
