The very popular Web Machinist Software Program is on sale now for only $49.00 ! Save $65 !
50+ Machining Related Calculators are included within the program.
You can check it out here at: WebMachinist.Net The Ultimate Online Source for Machinist Related Stuff!
This is a Great Chance to get the Web Machinist Software at this price!
This Software Program will save you Time and Money!
Web Machinist Software is an all inclusive program for windows computers (Windows 95, XP, 7, 8). 50+ Calculators Included!
All of the Calculators Listed are Included in the Program.
Calculators in the program include:
Angles Conversion Calculators
Degrees to Decimal Degrees
Decimal Degrees to Degrees
Degrees to Radians
Radians to Degrees
Area Calculators
Area of Circle, Including Radius, Circumferance, Diameter
Area of Square, Including Perimeter Distance, Distance Across Points
Area of Rectangle, Including Perimeter Distance, Distance Across Points
Area of Hexagon, Including Width of Flats, Distance Across Points
Blueprint Symbols
Chart of the Most Used Blueprint Symbols for Machinists
Bolt Circle Patterns Calculators
Full Circle Patterns, Up to 100 Points
Partial Circle Patterns, Up to 100 Points
Polar Points, Up to 12 Points in Ray
Chord to Diameter Calculations, Up to 100 Points
Wheel Bolt Patterns, Including 3 Bolt, 4 Bolt, 5 Bolt, 6 Bolt, 7 Bolt, 8 Bolt
Center Drill Dimensions Calculator
Center Drill Dimensions of #00000 to #10 Center Drills
Center Drill Program Depth Calculations for #00000 to #10 Center Drills
Circle Segments Calculators
Segment Calculated where Angle and Radius are Known
Segment Calculated where Chord Length and Chord Height are Known
Segment Calculated where Circle Radius and Chord Height are Known
Countersinks Calculator
Countersink Depth Program based on Countersink Angle and Desired Countersink Diameter
Custom Tap Calculators
To Calculate, Input Desired Basic Major Diameter, Thread Pitch, Thread Percent
Works for Inch Taps or Metric Taps
Works for Cut Taps and Form Roll Taps
Cutting Speeds Calculators
Surface Speed to RPM
RPM to Surface Speed
Inch or Metric Units
Dovetail Measuring Calculators
Measuring Male or Female Dovetails Using Pins
Measuring Dovetails Based on Desired Measurement Across Pins
Measuring Dovetails Across Pins Based on Desired Dimension
Drill Peck Calculators
Calculate Deep Hole Drilling Drill Pecks Without a Canned Cycle
Works for CNC Lathes and CNC Mills
G-Code Output
Calculate Same Peck Full Depth
Calculate Same Peck Partial Depth then Reduce Peck until Full Depth is Reached
Calculate Reduced Peck from Beginning until Full Depth is Reached
Drill Point Length / Depth Calculator
Calculate Drill Point Length based on Drill Diameter and Drill Tip Angle
Feed Rate Calculators
Inches Per Minute (IPM) Based on Inches Per Revolution and RPM
Inches Per Revolution (IPR) Based on Inches Per Minute and RPM
Inches Per Revolution (IPR) to Inches Per Minute (IPM)
Inches Per Minute (IPM) to Inches Per Revolution (IPR)
Inches Per Tooth (IPT) Based on Inches Per Minute, RPM, Number of Flutes / Teeth
Inches Per Revolution (IPR) to Millimeters Per Revolution (MMPR)
Inches Per Minute (IPM) to Millimeters Per Minute (MMPM)
Inches Per Tooth / Flute (IPT) to Inches Per Minute (IPM)
Inches Per Tooth / Flute (IPT) to Inches Per Revolution (IPR)
Inches Per Revolution (IPR) to Inches Per Tooth / Flute (IPT)
Gage Block Calculator
Input Desired Gage Blocks Height and the Calculator Lists the Needed Gage Blocks
Hole Location Inspection Calculators
Part Edge to Hole Center Using Pin
Part Edge to Hole Center Without Pin
Hole to Hole Without Pins
Hole to Hole Using Pins
Calculators Including:
Hole Location
Sine Bar / Sine Plate Set-Up
Dovetail Measuring
Gage Blocks Calculating
True Position Calculating
Thread 3 wire Measuring
Lathe Cross Slide Calculator
Calculate the Actual Infeed Amount of a Manual Lathe Cross Slide When Set at an Angle.
Simply Input the Desired Angle and the Handle Increment Amount and the Actual Infeed Amount on the Diameter is Calculated.
Lease Payment & Loan Amortization Calculator
Calculate Lease / Loans Based on Lease / Loan Amount, Interest Rate, Number of Payments
Calculate Lease / Loans Based on Lease / Loan Amount, Interest Rate, Desired Payment Amount
Create and Print Amortization Schedule
Machining Formulas Including 7 Calculators
Cutting Speed Formulas
Degrees Conversion Formulas
Drill Point Depth Formulas
Feed Rate Formulas
Metal Removal Formulas
Tapping Formulas
True Position Formula
Manual Machine Calculators
Cross Slide Feed In Calculating on an Angle
Tailstock Offset Calculating
Hex Pocket Endmill Compensating Calculating
Hex Points Calculating
Metal Removal Calculator
Time Cutting in Minutes (TCM)
Time Cutting in Seconds (TCS)
Cutting Distance Over Time
Metal Removal Rate (MRR)
Metal Weights Calculator
Calculate Weights of Aluminum, Alloy Steels, Brass, Bronze, Copper, Carbon Steel, Inconel, Magnesium, Monel Nickel, Stainless Steel, Titanium, Zinc
Shapes Supported, Round, Square, Rectangle, Hexagon
Metric Conversions Calculator
Conversions of Metric to Imperial (US)
Conversions of Imperial (US) to Metric
Mill Hex Pocket Calculators
Calculates the Endmill X,Y Points to Mill a Hex Pocket
Also Can Calculate the Hex Corner Points Too!
Right Triangles Solutions Calculators
8 Different Right Triangle Calculation Lay-Outs
Calculate Angles and Length of Sides
Simple Lathe Cam Tool Nose Radius Compensation Calculators
Calculate Tool Nose Radius Compensation for CNC Lathes
OD and ID Tool Nose Radius Compensation Supported
Cut-Off Tools Supported
Radius Angle Corners and Fillets if Needed
Full G-Code Output
Sine Bar Sine Plate Set-Up Calculator
Calculates the Gage Blocks Needed to Obtain Desired Sine Bar Angle
Calculates the Sine Bar Angle Based on the Gage Block Height Used
Printable Gage Block List
Smart Drill Index
Gives Drill Sizes for Fractional, Number Size, Letter Size, Metric Drills
Inch and Metric Equivalents
Provides Drill Speeds and Feeds for Various Drill Sizes for Many Materials
Soft Jaws Milling Calculators
CNC Mill Vise Soft Jaws Milling Made Easy
Input Pocket Style, Depth, Width, Length and Feed
Pocket with Left Stop
Pocket with Right Stop
Retangle / Square Pocket
Circle Pocket
No Stop Pocket
Full G-Code Output
Easy for Set-Up Operator to Use
Speeds and Feeds Conversion Calculator
Surface Feet Per Minute (SFM) to Revolutions Per Minute (RPM)
Revolutions Per Minute (RPM) to Surface Feet Per Minute (SFM)
Inches Per Minute (IPM) to Inches Per Tooth (IPT)
Inches Per Tooth (IPT) to Inches Per Minute (IPM)
Inches Per Tooth (IPT) to Inches Per Revolution (IPR)
Inches Per Revolution (IPR) to Inches Per Tooth (IPT)
Surface Meters Per Minute (SMPM) to Revolutions Per Minute (RPM)
Revolutions Per Minute (RPM) to Surface Meters Per Minute (SMPM)
Millimeters Per Minute (MMPM) to Millimeters Per Revolution (MMPR)
Millimeters Per Revolution (MMPR) to Millimeters Per Minute (MMPM)
Millimeters Per Minute (MMPM) to Millimeters Per Tooth (MMPT)
Millimeters Per Tooth (MMPT) to Millimeters Per Minute (MMPM)
Millimeters Per Tooth (MMPT) to Millimeters Per Revolution (MMPR)
Millimeters Per Revolution (MMPR) to Millimeters Per Tooth (MMPT)
Tailstock Offset Calculator
Calculates the Tailstock Offset Needed to Obtain a Desired Taper Per Foot Between Centers on a Manual Lathe.
It Also Can Calculate the Tailstock Offset Needed to Turn a Desired Angle Between Centers on a Manual Lathe.
Tapers Calculators
Taper Dimensions Given for:
Morse Tapers #0 thru #7
Jacobs Tapers JT0 thru JT33
Brown and Sharpe Tapers #1 thru #18
Jarno Tapers #2 thru #20
Calculate Custom Tapers too!
Tapping Calculators
Inch Cutting Taps 0-80 to 2.5-4
Inch Form Roll Taps 0-80 to 3/4-16
Inch Heli-Coil Cutting Taps 1-64 to 1.500-12
Metric Cutting Taps M1x2.5 to M68x6
Metric Form Roll Taps M1.6x3.5 to M10x1.5
Metric Heli-Coil Cutting Taps M2x.4 to M39x4
Tap Drill Sizes Provided
Suggested Feeds and Feeds Provided
Custom Tap Calculations, Inch, Metric, Cutting and Form Taps
Tap Drill Sizes
Tapping Speed & Feed Rates
Threading Calculators
Unified Threads 0-80 to 1-1/2-28
Metric Threads M.25x.075 to M600x6
Acme Threads 1/4-16 to 5-2 General Purpose and Stub
Metric Trapezoidal Threads TR8x1.5 to TR1120x44
Thread Dimensions, Including Major Diameters, Minor Diameters, Pitch Diameters
OD and ID Threads Supported
Program Feed Rates
3 Wire Pitch Diameter Calculating
True Position Calculator
Calculates True Position with Maximum Material Condition (MMC) or Without
Compares Actual True Position to Drawing True Position
Able to Print Results
Wheel Bolt Patterns Calculator
Find the Wheel Bolt Pattern Dimension for Wheels / Rims
Simply Input Stud or Hole Diameter and Distance Across Studs or Holes
Supports Inch and Metric Wheel Bolt Patterns
Works for 3 Bolt, 4 Bolt, 5 Bolt, 6 Bolt, 7 Bolt, 8 Bolt Wheel Bolt Patterns
3 Wire Thread Measuring Calculators
Calculates the Thread Pitch Diameter Measurements Using the 3 Wire Method
Calculate What Wire Size to Use
Calculate the Measurement Over the Wires
Calculate the Pitch Diameter Using Wires
Works for 60° Unified Threads
Works for 60° MetricThreads
Works for 29° AcmeThreads
Works for Metric 30° Trapezoidal Threads
Please Note: Upon Payment a Download link will be e-mailed to your PayPal e-mail address. Also a CD will be mailed to you.
To download a free demo to see if the program works for you, please click below:
http://www.webmachinist.net/downloadfreedemo.html
Below are a few Screen Shots from the program:
Above is the Main Screen of the "Web Machinist" software for windows computers.
Below is the Main Screen of "Simple Lathe Cam". As you can see there are 13 different Tool Radius Compensation calculators within "Simple Lathe Cam" 6 tool radius compensation calculators for the OD and 6 tool radius compensation calculators for the ID on parts running on a CNC Lathe. Also included is a "Cut-Off Chamfer Calculator"
In Simple Lathe Cam you can easily calculate tool radius compensation for angles and fillets or radii in both internal and external applications and part-off chamfers.
Below is the CNC Lathe OD Tool Radius Compensation Calculator Main Screen:
The above screen is the OD Simple Lathe Cam Screen.
Below is the ID Simple Lathe Cam Screen:
This screen is the ID Simple Lathe Cam Screen. Just by clicking on one of the tools a dialog similar to the one below will appear
Simple Lathe Cam can calculate the tool radius compensation needed to produce straight angles or angles with fillets or edge breaks and even generate the G Code needed!
This is an example of an ID tool compensation calculation.
Below is an example of a "Parting-Off" of a part with a chamfer:
With Simple Lathe Cam’s Cut-Off Chamfer Calculator you can easily generate the cnc G-Code needed to chamfer the back side of a part when cutting off the part with a parting tool. As you can see in the easy to follow dialog above all you have to do is enter the chamfer angle, x and z chamfer start points, the z cut-off position, the parting tool width, which side of the parting tool is the z offset set on and the corner radii of the parting tool if any (if none just enter 0). Optionally you can specify a desired edge break radius of the corners of the chamfer too and if you prefer to use "R" values or "I,K" values for the G-Code circular Interpolation commands.
The example above results in the screen below with all of the specific information and the resulting cnc G-Code :
Below is the Web Machinist "Drill Peck Calculator" in action"
With the "Drill Peck Calculator" you can easily calculate drill cycles with automatically reducing drill peck amounts, specify dwells at specific intervals, all automatically! Very nice for deep hole drilling. Works for CNC Mills and CNC Lathes.
Above is the Web Machinist "Inspection Calculators" main menu. As you can see Web Machinist includes various inspection tools to help make part inspection easier and more efficient.
The "Sine Bar Sine Plate Set-Cup Calculator" easily Calculates the Gage Block Height needed to set-up Sine Bars and Sine Plates. It even calculates the gage blocks to use from a standard 81 piece gage block set! Very Useful!
The "Gage Block Calculator" can calculate and list the gage blocks needed to obtain a desired gage block height from a standard 81 piece gage block set. A real time saver!
Above is the "Thread 3 Wire Measuring Calculator" where you can easily calculate the pitch diameter dimensions of both inch and metric threads when using thread wires.
Above is the "Circle Segment Calculator" where you can easily calculate the angle, segment length, height and circle radius.
Below is the "Area Calculator" where you can easily calculate the area of circles, squares, rectangles and hexagons.
Above is the main screen of the Web Machinist "Bolt Circle Calculator". You can easily Calculate "Full" Bolt Circle Patterns and "Partial Bolt" Circle Patterns, "Polar Point" Patterns and even Bolt Circle Patterns based on the "Chord" measurements. Even Common Wheel Bolt Circle Dimensions can be Calculated!
Below is an example of a "Partial" bolt circle pattern calculation.
Below is the main screen of the Web Machinist "Tapping Calculator".
The Web Machinist "Tapping Calculator" provides the tap drill sizes for both inch and metric taps. Cutting taps, form taps, roll taps and even helicoil taps. Feed rates and spindle speeds are also calculated and you can even calculate your own custom tap drill sizes!
Above is the Web Machinist "Threading Calculator" (above). Easily calculate the thread dimensions for threads 0-80 to 1 1/2-28 sizes including their decimal equivalents! External sizes even calculates the measure over wires when using the 3 wire method to measure thread pitch diameters. Very cool!
Above is the Web Machinist "Metric Threading Calculator" (above). Easily calculates the thread dimensions for threads M0.25x0.075 to M600x6 sizes including their inch equivalents! External sizes even calculates the measure over wires when using the 3 wire method to measure thread pitch diameters. Very cool!
The "Smart Drill Index" in Web Machinist allows you to reference the Drill Size and print each chart for reference. If you click on any drill in any of the charts you will open the Drill Speeds and Feeds chart for that particular drill as seen below:
The Drill Speeds and Feeds chart provides calculated drill speeds and feed rates in both inches per revolution and inches per minute base on the drill size, metal alloy and metal condition.
The "Metal Weights Calculator" easily calculates the weights of 13 different metal groups and their alloys for shapes: Round, Rectangle, Square and Hexagon. Very useful when preparing job quotes.
The "Center Drill Calculator" (above) not only provides the dimensions of Center Drills #0000 to #10, but also can calculate drill depths to obtain desired counter-sink diameters.
Cap screws dimensions are easily referenced in Button Head, Standard Head and Flat Head Styles in both Metric and Standard Measures.
Common Blueprint symbols used in machining are also referenced.
The "Countersink Calculator" (above) can easily calculate the drill depth needed to obtain counterink diamters. Just input the c-sink angle and desired c-sink diameter.
Web Machinist "Angles Converter" can convert angles from the standard angles format into a decimal form for easier calculations. It can also convert angles in a decimal form back into a standard angles format. Also it can convert angles into Radians and Radians into Angles!
Need to Calculate the measurements for DoveTails? No problem with the "DoveTail Measuring Calculator" Both Inside and Outside Dove Tails are supported.
The "Metric Conversion Calculator" can convert common Metric Measurements to Common Imperial ( U.S.) and Imperial (U.S.) Measurements to Metric Measurements.
The "Hole Location Calculator" can easily calculate the actual measurement from an edge to the center of a hole (above) or between 2 holes as seen below:
Need to calculate a lease or loan payment? Generate an amortization schedule? The "Lease Payment Calculator" (above) can do it for you!
Self Tapping Screws dimensions are easily referenced too!
Spindle Speed Calculator (Above) can convert surface speeds to RPM and RPM to Surface Speed in both U.S. Units and Metric Units.
Right Triangle Calculations are easily made using the "Right Triangles Solutions Calculator". (See Above)
Above is the main screen of the Web Machinist “Speeds and Feeds Conversion Calculator”. There are 4 speed conversions available including: “Surface Speed in Feet Per Minute” to Revolutions Per Minute ( RPM), Revolutions Per Minute ( RPM ) to “Surface Feet Per Minute, “Surface Speed in Meters Per Minute” to RPM and RPM to “Surface Meters Per Minute”. Also included in the Web Machinist “Speeds and Feeds Conversion Calculator” are 12 Feed Conversions available including: “Inches Per Minute” to “Inches Per Revolution”, “Inches Per Revolution” to “Inches Per Minute”, “Inches Per Minute” to “Inches Per Tooth”, “Inches Per Tooth” to “Inches Per Minute”, “Inches Per Tooth” to “Inches Per Revolution”, “Inches Per Revolution” to “Inches Per Tooth”, “Millimeters Per Minute” to Millimeters Per Revolution”, “Millimeters Per Revolution” to “Millimeters Per Minute”, “Millimeters Per Minute” to “Millimeters Per Tooth”, “Millimeters Per Tooth” to “Millimeters Per Minute”, “Millimeters Per Tooth” to “Millimeters Per Revolution”, “Millimeters Per Revolution” to “Millimeters Per Tooth”. (See Above)
Above is the "True Position Calculator". You can calculate the True Position of holes with the Maximum Material Condition (MMC) callout or without it. Very easy to use and fast! A real time saver.
Above is the "Soft Jaws Milling Calculator". You can easily calculate and program the tool path for various soft jaws such as "Rectangle Pocket", "Left Stop", "Right Stop", Through Jaws (no stop) or Circle Pockets". Very easy to use and fast! A real time saver when making a machine set-up.
"Wheel Bolt Pattern Calculator".
Below is the newly updated "Machining Formulas Reference Guide with Calculators". Now each of the formulas lists also has a built in calculator. Simply click on the calculator icon to open the calculator for that particular formula set. See below:
As an example if you were to click on the Calculator icon in the Cutting Speeds Formulas window, it would open the Cutting Speeds Calculator seen below:
In the Cutting Speeds Calculator seen above you can calculate RPM to Surface Feet per Minute or Surface Feet per Minute to RPM or Surface Feet per Minute to Surface Meters per Minute.
Below are more examples of the Web Machinist Machining Formulas Reference Guide and Calculators:
Above is the Degrees Conversions Formulas Reference Guide.
The Degrees Conversion Formulas included are:
Converting Minutes of a Degree to a Decimal
Converting Minutes and Seconds of a Degree to a Decimal
Converting Decimal Degrees to Minutes
Converting Decimal Degrees to Minutes and Seconds
Converting Degrees to Radians
Converting Radians to Degrees
Below is the Degrees Conversions Formulas Reference Guide Calculator Screens:
The Drill point Depth Formulas Guide seen below list the formulas for calculating the drill point length of 60 degree, 82 degree, 90 degree, 118 degree, 120 degree, 135 degree tip angled drills. See below:
The Drill Tip Length Calculator seen above can easily calculate the drill tip length of standard drill point angles or you can input a custom angle for the calculation and have the drill tip length calculation output in either inches or millimeters.
Below is the resulting calculation from the example above:
Above is the Feed Rate Formulas Reference Guide. Formulas for the following are given in the guide:
Feed Per Revolution (FPR)
Feed Per Tooth (FPT)
Convert Inches Per Revolution (IPR) to Inches Per Minute (IPM)
Convert Inches Per Minute (IPM) to Inches Per Revolution (IPR)
Convert Inches Per Revolution (IPR) to Millimeters Per Revolution (MMPR)
Convert Inches Per Minute (IPM) to Inches Per Tooth (IPT)
Convert Inches Per Tooth (IPT) to Inches Per Minute (IPM)
Convert Inches Per Tooth (IPT) to Inches Per Revolution (IPR)
Convert Inches Per Revolution (IPR) to Inches Per Tooth (IPT)
Below is an example of the Feed Rate Formulas Guide Calculator in action:
As you can see in the Feed Rate Calculator screen shot above, you can easily perform feed rate calculations and conversions for:
Inches Per Revolution to Inches Per Minute
Inches Per Minute to Inches Per Revolution
Inches Per Revolution to Millimeters Per Revolution
Inches Per Minute to Millimeters Per Minute
Inches Per Tooth to Inches Per Minute
Inches Per Tooth to Inches Per Revolution
Inches Per Revolution to Inches Per Tooth
Above is the Metal Removal Formulas Reference Guide.
The metal removal formulas listed are:
Distance Over Time
Metal Removal Rate (MRR) (Cubic Inches Per Minute)
Below is an example of the Metal Removal Rates Formulas Reference Guide Calculator in action:
Above is the Metal Removal Calculator of the Machining Formulas Reference Guide. As you can see, you can calculate the following:
Time Cutting in Minutes, where you input the length of the cut and the feed rate in inches per minute and the Metal Removal Calculator will calculate the time it takes to make the cut in minutes and seconds.
Time Cutting in Seconds, where you input the length of the cut and the feed rate in inches per minute and the Metal Removal Calculator will calculate the time it takes to make the cut in seconds and minutes.
Distance Over Time, where you input the time the cut takes and the feed rate in inches per minute and the Metal Removal Calculator will calculate the distance of the cut in inches and millimeters.
Metal Removal Rate, where you input the width of the cut, the length of the cut and the feed rate in inches per minute and the Metal Removal Calculator will calculate the cubic inches of metal being removed per minute. See the example above.
Above is the Tapping Formulas Reference Guide.
The tapping formulas listed are:
Calculating Tap Drill Size for "Inch" Cutting Taps
Calculating Tap Drill Size for "Metric" Cutting Taps
Calculating Tap Drill Size for "Inch" Fluteless Roll Forming Taps
Calculating Tap Drill Size for "Metric" Fluteless Roll Forming Taps
Below is an example of the Tapping Formulas Reference Guide Custom Tap Calculator in action:
With the Custom Tap Calculator ( above ) you can calculate the tap drill size for Inch Cutting Taps, Inch Form or Roll Taps, Metric Cutting Taps, Metric Form or Roll Taps. Also the Custom Tap Calculator will calculate the spindle speed for common metals based of the tap calculated tap size and calculate the feed rate in inches per revolution, inches per minute and millimeters per revolution.
The True Position Calculating Formula section of the Machining Formulas Reference Guide is seen above.
The True Position Calculator for this section of Machining Formulas is seen below with an example:
The True Position Calculator in the Machining Formulas Reference Guide ( above ) can calculate the true position tolerance for both True Position Only and True Position with Maximum Material Condition.
Above is the Tapers Calulator where you can view the dimensions for Morse Tapers, Jacobs Tapers, Brown & Sharpe Tapers and Jarno Tapers in both Inches and Millimeters.
