You all must be fed up of hearing from me now and my questions
Sorry there's another one.
How are you tramming and keeping the spindle straight effectively without it just moving? My spindle mount has a lot of play for the spindle to move around inside but not much potential to align the mount against the z plate as the bolt holes are very close fitting. I noticed today my tramming was no longer straight parallel to the X and when I measured it it wasn't far off 1mm out over a 70mm swing. The only way to get any meaningful adjustment more than a few hundredths of a mm is by having the spindle slightly lopsided in the mount, but it's so easy to knock straight back out, even cranking on the collet nut to change a tool knocks it out of alignment. I dread to think what's happening when it's actually making a cut.
Front to back is fine as that's shimmed with precision tin foil.
Dharmic I remember you posting about moving the spindle up and down in its mount a lot, do you have to realign it every time?
