586,094 active members*
3,709 visitors online*
Results 1 to 11 of 11
    KH 750 60W Power issues on new laser
    Hi
    I am hoping the clever people who hang out on this forum can help me with a issue I am having with a new laser. I have taken delivery of a KH750 details
    RDC6442G controller
    KH Lazer Tube - 1000mm x 50mm 60w
    Software - RDWorks V8
    The issue I am having is that the laser power is way down. When firing the laser tube glows pink, but placing a piece of plywood in the beam on the second mirror only produces a weak burn (See pics) The depth of burn at 10 second is 1mm.
    I have checked the beam path and it in in the middle of each mirror and the lens.
    I have cleaned the lens
    Using the software I have set the power to 90% min and 90% max at 3mm/s but all I get is a light mark on wood.
    Setting the power to 90% on the panel and firing the laser via pulse makes a faint mark.
    I have checked the water flow and temperature and have run the tests at 20 deg C.
    I cannot see any damage on the tube, but that is always a possibility.
    Before taking on the cost of a new tube I am looking for any suggestions of settings or tests I can run to prove it is the tube.
    I have been looking for a replacement tube but the 60W 1000mm x 50mm seems a rare beast, so if anyone knows of a supplier or manufacutrer in the UK or China , information would be greatly received.
    Thanks for any responses.
    Re: KH 750 60W Power issues on new laser
    Hi ,my friend
    what is the material and thickness do you want to cut ?
    for a 1000mm length tube , the power can not up to 60W
    The problem is the tube , the power is weak .
    If you want to cut thickness material and get quick speed , you need
    change your power supply and tube together .
    co2 laser machine&parts. tubes,lens,mirrors,DSP control systems ,powers etc .
    Email/Skype:[email protected]:86-18516298692.
    Jan 2008
    940
    Have you aligned the beam. Is the beam hitting the nozzle. is the focusing lens in place and are you at the correct focal point.
    Only 3 to 5 mm - I have a 40w laser that can do these no issue.
    Is there a min power requirement for the tube to fire?
    Quote Originally Posted by frank wang View Post
    Hi ,my friend
    Quote Originally Posted by fixtureman1 View Post
    Yes. I have aligned the beam all along the path and done a sloped cut (by which I mean mark as it will not cut) and the focal length is 20 mm as per the guide supplied with machine.
    I can only think that I am going to need to get someone to check the power supply.
    Jan 2008
    940
    even if you do a slope test thebeam could be hitting the side of the nose cone I had that happen to me and it would mark but not cut
    Jul 2012
    8
    Hi mwbaker. I have a similar problem with my new 60w kh laser. It runs perfectly just not enough power to cut like it should. All my research pointed to a new tube and power supply which I have just ordered. Will let you know how it works out
    Aug 2015
    Quote Originally Posted by mwbaker63s View Post
    Hi
    RDC6442G controller
    I bought one exactly the same and I'm not getting cut anything .. already lined lenses but nothing ..
    You fixed your machine ?
    Jan 2008
    940
    I just reread your post and if you get a burn like that at the second mirror then you should get a good beam out the nose cone. You will need to align the mirror on the head to hit the center of the lens.
    Nov 2008
    643
    No power out of the nozzle usually is from alignment. Or lens is backwards. You can check the ma out of the tube with a shunt and amp meter. They also sell ma meters for lasers. You should get to at least 20 for a high power cut
    Nov 2010
    I too have the same laser. Did you ever resolve your issue?
  1. GW LC 1290 Laser Power Supply Not out puting power
    By cnarch in forum G.Weike Laser
    Last Post: 11-25-2013, 05:26 AM
  2. Power Up Issues with Sabre 750
    By flyinphill in forum Cincinnati CNC
    Last Post: 11-23-2013, 03:47 PM
  3. Having issues with my TTS & Power Drawbar
    By mooreaa in forum Tormach Personal CNC Mill
    Last Post: 12-04-2011, 03:00 AM
  4. Spindle Power Issues
    By thackman in forum Syil Products
    Last Post: 12-01-2007, 09:57 AM
