586,062 active members*
4,443 visitors online*
Results 1 to 7 of 7
    Jun 2015
    18
    Fanuc 0i-MD - DNC over Ethernet
    I have my control connected to the FTP server and want to run the DNC programs from the FTP server.
    It's posible?
    thank you very much
    Popex
    Nov 2006
    175
    Re: Fanuc 0i-MD - DNC over Ethernet
    Fanuc 0i-MD - from software version 37 or 38 it is possible. Sorry, can not remember right version, but from middle of March, 2015
    Jun 2015
    18
    Quote Originally Posted by f-bu View Post
    Ok. How I can see the software version of my machine? You can update the soft?
    Nov 2006
    175
    Try to find parameter 14885. If present, set bit1=1. The soft version can be seen on SYSTEM-SYSTEM
    Attachment 286068
    Jun 2015
    18
    Very well, I'll try.
    Thank you very much!
    Jun 2015
    18
    Fbu Hello, unfortunately I do not have that ... not have been available parameter control is available for the modification of that value. I have 0i-MD.
    Thank You
    Aug 2011
    2517
    DNC via ethernet is an option. if you don't have the option you won't see that parameter or have that functionality.
    either way, if the function was only available from the middle of March 2015, you are unlikely to have it unless you bought your machine new within the last 3 months.....
    for software version, as stated above, press SYSTEM hard key then SYSTEM soft key. software version is available there by using page up/page down to find the screen with software versions.
  1. Ethernet Fanuc 18i-TB
    By ProToZyKo in forum Fanuc
    Last Post: 03-14-2019, 02:42 AM
  2. Fanuc DNC with Ethernet
    By elab.ess in forum Fanuc
    Last Post: 07-14-2014, 11:41 AM
  3. connecting to fanuc via ethernet
    By beartrax in forum Mori Seiki lathes
    Last Post: 08-27-2012, 04:50 PM
  4. Fanuc 18i MB ethernet networking
    By Wheel in forum Fanuc
    Last Post: 01-14-2009, 06:11 AM
  5. Fanuc OM ethernet connection
    By Porknar in forum Fanuc
    Last Post: 09-25-2006, 03:11 PM
