Plasma table kit with 11' x 6' water table
I have a complete kit with everything needed to build a plasma / router table for sale. My business has moved in a different direction, and I no longer need this table.
If you are getting ready to build a new table, don't waste your time sourcing all the parts - I have everything you need!
You get everything on top of the table in the pictures below.
Includes all these brand new parts:
Everything on the BOM from the Shop Droids / No Sleep Studio Ultimate DIY RouterBot 3.0 HD Gantry Kit
ShopDroids Z Axis Drive option with all materials
Z Drive Floating Torch Plate Kit
Ultimate DIY 3.2:1 Gear Reduction Drive Plates
CandCNC MP 3000 DTHC II torch height controller, with the MIC-01 cable
4 new motors - G540 4-Axis NEMA23 381oz in, PSU 48v/12.5a kit from Automation Technology Inc
IVTAAQ v-rail for the X axis - 1 piece 12' long
IVTAAN v-rail for the Y axis - 2 pieces 12' long
TSLOTS Structural Extrusion 40mm x 80mm - 1 piece 7' long
Gear rack - Steel 20 Deg Pressure Angle Spur Gear Rack 20
Pitch, 1/2" Face Width, 1/2" Height - 2 pieces 12' long for Y axis and 1 piece 7' long for the X axis. Also a spare piece about 2' long.
1000' of 18/4 wire for connecting the motors.
All the nuts, bolts, washers, springs, clamps, set screws, etc that you need to fully assemble the kit. You provide the plasma cutter and a computer.
The table has a built-in water bed that measures exactly 11' by 6'. The bottom of the water bed is sloped towards the back to help make it easy to drain. I did not have time to add a drain hole, so you can customize that to your needs.
Pick up in Olive Branch, MS, just outside of Memphis, TN. I can help load onto your trailer.
I have $5,000 invested in these parts. Open to reasonable offers.
List Date: 7/9/2015
For more info, click here to view the original listing: Plasma table kit with 11' x 6' water table
On Sale For: $1.00 (Local Pickup Only)
Mobile friendly version: Plasma table kit with 11' x 6' water table
Go Mobile: Download the free Panjo iOS app now!
