586,082 active members*
3,640 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i-MD - Faceted with AICC 2
Results 1 to 2 of 2
Threaded View
    Jun 2015
    18
    Hi, I made this piece machining, and how they see this faceted. The program is made with a CAM. I tried raising and lowering the tolerance, increase and reduce the amount of points. But keeps coming faceted.
    I am with AICC 2 activated with G05.1 Q1 command (or P1, I can not remember at the moment) and working with a velicidad 1200mm / min.
    The truth will never use this control and not to configurations should be modified, but in other controls have not had this problem.
    I know I can solve programming with G02 and G03 ... but I need to solve a point to point program. When you generate a complex surface in 3D it is going to have to be if or point to point.
    thank you very much
  1. toolpath is too faceted.
    By declanhalpin in forum MadCAM
    Last Post: 04-18-2013, 03:30 AM
  2. contoured path is faceted?
    By fjbart70 in forum Bridgeport / Hardinge Mills
    Last Post: 06-26-2011, 03:55 PM
  3. FACETED ELLIPSE
    By cncstephen in forum Mastercam
    Last Post: 06-15-2011, 10:23 AM
  4. Fanuc 21i-mb AICC settings
    By contour in forum Fanuc
    Last Post: 01-21-2009, 08:58 AM
  5. Aicc/hpcc Vs Hsm (non Fanuc)
    By highspeedmike in forum Hard / High Speed Machining
    Last Post: 08-24-2007, 01:49 AM
