586,036 active members*
3,576 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Kollmorgen BDS4 206 23 possible failure
Results 1 to 6 of 6
    Jul 2015
    13
    I have a kollmorgen BDS4 driver connected to a 5th axis on a Cincinnati arrow 1000, at first a thought that the servomotor had some kind of failure because it was making a noise, I took it out and found that the noise its because the servomotor was going back and forward to fast that is vibrating. I connected the servomotor to the 4th axis driver and it worked fine, it was stable. so I assume that something is wrong with the driver.
    does anyone have had the same experience?
    Oct 2004
    178
    Re: Kollmorgen BDS4 206 23 possible failure
    Sounds like your motor tuning parameters are off. Try reducing the proportional gain until the dithering stops, then reduce it a little more.
    Jul 2015
    13
    Thanks for your replay!!
    based on what you told, I looked in to the control maintenance manual and I found a servo adjustments section. here are some pictures of it.
    Attachment 286180Attachment 286182
    is this what I have to do?
    best regards,
    Sep 2010
    1765
    No. Try ccw turn Single turn pot top front of drive marked stability.
    If not fix, did it used to work?
    Is it comped for the troyke table?
    Did anyone turn the scale pot?
    Jul 2015
    13
    Quote Originally Posted by mike_Kilroy View Post
    I have not fix it yet, I sent an email to kollmorgen, and they told me I can adjust it from the driver, just like you are telling me. I found the driver's manual and it says how to adjust the stability. it says to adjust it properly I need a oscilloscope to track the internal tack signal and the current signal.
    no, nobody has turn the scale pot, I just bought the machine and installed. I am trying to fix everything that does not look like is working properly. I am new with CNC machine. so I am learning.
    thank you for your post!!
    Sep 2010
    1765
    Quote Originally Posted by JFYM88 View Post
    You can adjust without scope; put your hand on table and feel the vibration (oscillation), turn stability CCW until vibration goes away.
    Or watch a2100 screen position or following error; adjust CCW until not shaking around more than the other axes.
    Speed scale is very important to be correct or it will causing oscillation - BUT SLOW oscillation, like back and forth typically once or twice or five times a second - slow. Stability is like 100 or 200 or 300 times/sec. So armed with this knowledge you can decide which needs adjustment. speed pot adjust check: command max table speed and measure analog command to drive (top 2 terminals on big molex connector). should be around 7-9vdc if adjusted right.
  1. BDS4 OverSpeed Fault,
    By dyakush in forum Cincinnati CNC
    Last Post: 04-07-2014, 02:30 AM
  2. Arrow 500, AC2100, BDS4 Overspeed Fault
    By dyakush in forum Haas Mills
    Last Post: 04-05-2014, 06:35 PM
  3. Kollmorgen AKD
    By banksviolette in forum Servo Motors / Drives
    Last Post: 06-26-2012, 12:30 AM
  4. vsd and kollmorgen servodisc
    By tomekscnc in forum CNC Machine Related Electronics
    Last Post: 03-09-2012, 08:13 PM
