586,070 active members*
3,607 visitors online*
    May 2008
    4068
    Precision cnc milling machine test build
    Hope to get casted within a couple weeks . Casted in Canada
    Will be completely surface ground on all connecting surfaces .
    Here is the base, will post complete set up
    SBC linear blocks and rails. 20mm
    SBC ground 20mm ballscrew
    Leadshine Easy servos 110v
    Attachment 286308 Attachment 286310
    XZero cnc
    Aug 2014
    889
    Re: Precision cnc milling machine test build
    Looks good, but you are not showing any draft on the vertical walls, which should be a minimum of 3 degrees, unless you have designed a complex pattern with individually removable pieces.
    If cast as a loose pattern you need draft.
    Think how are you going to remove the pattern that hollows out your rail supports on the bottom side with the two X's there?
    Also, what size work envelope?
    May 2008
    4068
    Quote Originally Posted by G59 View Post
    Rails are all pocketed, and surface ground .They are not just flush mounted. Parts has changed a bit from final part from in picture . yes there is draft on the model .
    10x12x10 travel it will have . Base is 350X750MM
    XZero cnc
    Aug 2014
    889
    Don't forget fillets.
    May 2008
    4068
    This is final and machined model and casting this week I hope.
    350 pounds for base and column
    Attachment 286516 Attachment 286518
    XZero cnc
  1. CNC Milling machine backlash test
    By AVRnj in forum Benchtop Machines
    Last Post: 11-20-2013, 04:01 PM
