586,033 active members*
3,481 visitors online*
Results 1 to 7 of 7
    Jul 2009
    35
    Unhappy Takisawa TC-10 Fanuc 21TB
    Hey guys
    Hope someone can help.
    I am still searching the forum, but....
    I bought a TC-10 that has been standing around two years.The IO board is missing, but it looks as if that one is sorted.
    The machine is still standing on a trailer, to be offloaded, but my grimy little hands could not resist to start tinkering. What I have seen so far is some slight wiring problems on the MTB side (footswitch wiring shorting) as well as Fanuc side (ribbon cable to CRT softkeys are damaged). Those are most probably the reasons the IO is missing in the first place. I am still going to trace through all the wiring anyways.
    If I do get the IO. What will the procedures be? Will the machine start up as normal, or will I have to install the software and parameters again?
    I also have zero paperwork on the machine I need anything that can be given: Operators manual, electric diagrams, parameter lists, ladder diagrams, 21 TB Fanuc manuals, etc, etc.
    Can anyone help?
    Aug 2011
    2517
    Re: Takisawa TC-10 Fanuc 21TB
    Fanuc 21 Connection Manuals
    Fanuc 21/210-Model B Connection Manual (Hardware) GFZ-62703EN
    Fanuc 21/210-Model B Connection Manual (Function) GFZ-62703EN-1
    Fanuc 21 Descriptions Manual
    Fanuc 21/210-Model B Descriptions Manual GFZ-62702EN
    Fanuc 21 Maintenance Manual
    Fanuc 21 Model B Maintenance Manual GFZ-62705EN
    Fanuc 21 Parameter Manual
    Fanuc 21/210-Model B Parameter Manual GFZ-62710EN
    Fanuc 21 Lathe Operator's Manual
    Fanuc 21–TB/210–TB Operator’s Manual GFZ-62534E
    Fanuc 21 Mill Operator's Manual
    Fanuc 21–MB/210–MB Machining Center Operator’s Manual GFZ-62704EN
    This is the full set of Fanuc 21 manuals...... found with a simple 5 second google search.......
    Jul 2009
    35
    Hi Forda, thanks. I found the Fanuc manuals as well after posting on a CNC specific forum. The Takisawa manuals are elusive though. I will search some more tonight.
    Thanks again.
    Aug 2011
    2517
    you wont find Takisawa pdf manuals online they are not available. in fact almost no machine manufacturer manuals are online.
    Oct 2018
    I am in need of takisawa tc10 fanuc 21T backup.
    Jul 2009
    35
    Hi smmoorthieee. I have a full control to part out. I have retrofitted to Linuxcnc. Don't know where you are, but I am in South Africa.
    Jun 2022
    Hello
    I need setting parameter for takisawa TC-10 fanuc 21TB, any one can help me to copy setting parameter
  1. Harisson self learning lathe with fanuc 21TB
    By tmbruno28 in forum Fanuc
    Last Post: 01-26-2014, 04:10 PM
  2. Post for Daewoo w/Fanuc 21TB
    By ProgSol in forum Surfcam
    Last Post: 03-11-2011, 10:05 PM
  3. Problem with G02/G03 on Fanuc 21tb
    By dj_deadman666 in forum Fanuc
    Last Post: 04-16-2010, 08:29 AM
  4. Takisawa TC-1 with Fanuc OT
    By Nilesh Patel in forum Fanuc
    Last Post: 10-23-2008, 07:13 AM
  5. Takisawa/Fanuc 3T
    By hammerdown in forum Fanuc
    Last Post: 10-17-2008, 03:06 PM
