586,119 active members*
3,525 visitors online*
    Jul 2014
    Mitsubishi EDM Servo Alarm
    Hello,
    I have a Mits DWC110 with MELDAS FCA330HW Control, i has been down for a while and batteries were dead. We replaced them and had to reload the system software.
    Before loading the pitch error correction and backlash & e-pak floppy disks, we need the machine to be ready.
    On the maintenance alarm screen, we have a S03 SERVO ALARM: NR 0045 V
    I understand that there is a problem with the V Servoamplifier, and the manual says the thermal protection probably has been damaged. I dont have the electrical diagram of this machine. But i do have the other ones.
    Do anyone know where is this ServoAmplifier located in the machine??
    I can only see the X & Y Amplifier on the electrical cabinet.
    Best Regards.
    Jul 2014
    Re: Mitsubishi EDM Servo Alarm
    Any help would be greatly appreciated
    Thanks.
    Jul 2015
    15
    You may have found the right spots already -
    X Amplifier should be the servo amplifier of X axis (the servo motor of X axis)
    Y Amplifier should be the servo amplifier of Y axis (the serve motor of Y axis)
    Just find out which amplifier is defect and replace it with a working one.
    A blacksmith
    Jul 2014
    Thank you, i have found it.
    It it the rightest to the right side of the X/Y Servoamplifer.
    Best regards
Name:	U-V servoamplifier location.png
  1. S03 alarm on mitsubishi
    By mik*2 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-04-2023, 04:30 PM
  2. Mitsubishi servo amp MDS-A-SVJ-03 alarm
    By BRmaintenance in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2012, 01:26 PM
  3. Mitsubishi Meldas LOB Servo OCP alarm
    By Whiteforest in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-02-2010, 12:05 PM
  4. Mitsubishi IPM overheat alarm
    By rjboz in forum Daewoo/Doosan
    Last Post: 12-22-2006, 09:46 AM
