586,058 active members*
4,691 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak qt10n with servo oscillation in all axis!!!
Results 1 to 7 of 7
    Jul 2014
    Hello, last days i've been dealing with a Mazak with CAM T3 Controller that stoped working because a lag excess in x axis.
    The problem has evolved and I have lag excess alarm and servo oscillation alm in all axis, it happens just before the machines starts up, it boots up with all this alarms:
    1- ServoLag excess x axis
    2- ServoLag excess z axis
    3- ServoLag excess c axis
    5- Servo Oscillation
    6- Servo Oscillation
    7- Servo Oscillation
    15- Drive alarm (C) (Sometimes)
    20- NMI Watchdog Alarm
    181- MES Alarm (Sensor not on)
    182- Sensor on not in measuring
    Any ideas? Anything would be aprreciated!
    Oct 2003
    321
    Re: Mazak qt10n with servo oscillation in all axis!!!
    Initial. The Mazatrol
    Jul 2014
    Quote Originally Posted by mazak-user View Post
    I don't understand , what do you mean by initial?
    Thank you
    Oct 2003
    321
    Give me your mailadress, I will send you a procedure.
    Jul 2014
    I think it is a problem inside the control. Look at the pictures attached, I have disconnected the I/Os and the servoamplifiers and still get that errors as system starts.
    What card could be the problem?
    Jul 2014
    [email protected]
    Oct 2015
    4
    I think some parameter are missing from your system, i am sending you parameter list of mazak QT10N atc T3. first you do priority reset as per maintenance manual then enter. then all will resolved. how to attach this list tell me the procedure.
    Ramesh Kumar
    Ph- +91-8802030303
    INDIA
  1. Mazak QT10N T2 - Basics
    By ic-cnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-03-2015, 12:06 PM
  2. Parameter MAZAK QT10N with T2 Control
    By sudirmi in forum Chinese Machines
    Last Post: 10-27-2014, 04:00 AM
  3. Mazak QT10N with FANUC 10T control
    By ag_engineers in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-29-2014, 09:39 AM
  4. Need help with Mazak QT10N ATC T3 manuals and parameters
    By Donatello Tam in forum Chinese Machines
    Last Post: 12-04-2013, 05:52 AM
  5. servo oscillation
    By nebyeh in forum Servo Motors / Drives
    Last Post: 02-25-2007, 12:14 PM
