success!
Here's what was returned: What's it telling me?
General configuration information:
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: PWM
There are 2 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4000
ClockFrequency: 200.000 MHz
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 4 Table3 (Out)
14 1 IOPort Null 0 Null3 (null) (In)
2 2 IOPort StepGen 0 Table3 (Out)
15 3 IOPort Null 0 Null3 (null) (In)
3 4 IOPort StepGen 0 Table3 (Out)
16 5 IOPort Null 0 Null3 (null) (In)
4 6 IOPort StepGen 1 Table3 (Out)
17 7 IOPort PWM 0 /Enable (Out)
5 8 IOPort StepGen 1 Table3 (Out)
6 9 IOPort StepGen 2 Table3 (Out)
7 10 IOPort StepGen 2 Table3 (Out)
8 11 IOPort StepGen 3 Table3 (Out)
9 12 IOPort StepGen 3 Table3 (Out)
10 13 IOPort Null 0 Null3 (null) (In)
11 14 IOPort Null 0 Null3 (null) (In)
12 15 IOPort Null 0 Null3 (null) (In)
13 16 IOPort QCount 0 Quad-IDX (In)
IO Connections for P2
1 17 IOPort StepGen 9 Table3 (Out)
14 18 IOPort Null 0 Null3 (null) (In)
2 19 IOPort StepGen 5 Table3 (Out)
15 20 IOPort Null 0 Null3 (null) (In)
3 21 IOPort StepGen 5 Table3 (Out)
16 22 IOPort Null 0 Null3 (null) (In)
4 23 IOPort StepGen 6 Table3 (Out)
17 24 IOPort PWM 1 /Enable (Out)
5 25 IOPort StepGen 6 Table3 (Out)
6 26 IOPort StepGen 7 Table3 (Out)
7 27 IOPort StepGen 7 Table3 (Out)
8 28 IOPort StepGen 8 Table3 (Out)
9 29 IOPort StepGen 8 Table3 (Out)
10 30 IOPort QCount 1 Quad-IDX (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-IDX (In)
13 33 IOPort Null 0 Null3 (null) (In)
Finished machining new encoder wheel... still waiting for sensors to arrive..
Attachment 361218..
Perfect so now it's just software which we can help with!
You have two quadrature counters.
This is the external DB25IO Connections for P3
And the external DB25 has only the index channel of encoder counter 0 internally connected to a pin (which is wierd). It is GPIO number 16 and is on physical pin 13.Code:Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort StepGen 4 Table3 (Out) 14 1 IOPort Null 0 Null3 (null) (In) 2 2 IOPort StepGen 0 Table3 (Out) 15 3 IOPort Null 0 Null3 (null) (In) 3 4 IOPort StepGen 0 Table3 (Out) 16 5 IOPort Null 0 Null3 (null) (In) 4 6 IOPort StepGen 1 Table3 (Out) 17 7 IOPort PWM 0 /Enable (Out) 5 8 IOPort StepGen 1 Table3 (Out) 6 9 IOPort StepGen 2 Table3 (Out) 7 10 IOPort StepGen 2 Table3 (Out) 8 11 IOPort StepGen 3 Table3 (Out) 9 12 IOPort StepGen 3 Table3 (Out) 10 13 IOPort Null 0 Null3 (null) (In) 11 14 IOPort Null 0 Null3 (null) (In) 12 15 IOPort Null 0 Null3 (null) (In) 13 16 IOPort QCount 0 Quad-IDX (In)
And this is the internal headerIO Connections for P2
And this is saying that you have three pins for the index of encoder counter 1. (You would expect something like:Code:Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir ... 10 30 IOPort QCount 1 Quad-IDX (In) 11 31 IOPort QCount 1 Quad-IDX (In) 12 32 IOPort QCount 1 Quad-IDX (In) 13 33 IOPort Null 0 Null3 (null) (In)
So something doesn't really make sense. I am suspecting a slight bug in Mesaflash. Perhaps it identifies all pins as IDX. Though it works OK on the 7i80 I have here as the output above shows.Code:11 48 IOPort QCount 2 Quad-IDX (In) 12 49 IOPort QCount 2 Quad-B (In) 13 50 IOPort QCount 2 Quad-A (In)
Pretty sure that (weird index only counter) is due Tormachs funny bitfile for hardware interpolated position
support for the (1 wire) RapidTurn interface
To do standard quadrature would require a new bitfile (which is pretty trivial)
or perhaps adding a base thread and using a software encoder module if the encoder resolution is low enough
trivial for you,, difficult for me
new encoder has 40 teeth. so 40 As & 40 Bs or 80 between the two, or 160 state changes.. whichever value is important - is that low enough? I could make it lower if need be. Mechanical Design I know.. bitfiles are voodoo .
durn post office sent my digikey order to the wrong city... even though I used their own zip code system!!
You should try living in a town named California, in a different state! Lol Government offices and the post office in particular can't seem to get their heads around it.
Terry
Lordy, I cant even imagine that. what state?
I'm in San Diego, Ca.. there's a town in Texas also called San Diego that I visited maybe 20 years ago. Little dump of a place, almost exclusively Mexican population. Most of their street names also existed in my city. They had some interesting tales of confusion
SocalPlanedoc- I think if you ask PCW to alter the bitfile so that there is and index, a, and b pulses instead of 3 index pulses you'll be all set to start modding the Hal file.
I'm in Maryland, California is next to another small town named Hollywood! Hollywood wasn't named after the California version, it's just an area that is covered in wild Holly trees. I do believe that California got it's name because some joker thought it would be funny. When I first came here back in the 70's I moved from San Diego (best weather on the planet), I had a California drivers license, and they kept mailing my renewal to Hollywood, CA. Drove around for a month on an expired license before they unscrewed it.
Terry
Its easy to make a bitfile that has a full encoder on P2, but there are a couple of side effects:
1. You need to defeat Pathpilots re-flashing the 5I25 with Tormachs bitfile
2. Rapidturn support would be lost (you would need to go back to Tormachs bitfile for this)
3. You of course need to modify the hal and ini files to connect and scale the encoder
Can one (certainly not me!) create a bitfile supporting Rapidturn on P1 and a full encoder on P2?
Yes, its certainly possible, but may require some driver/hal file changes to merge support for position interpolation (AFAIK Tormachs firmware
uses hardware position interpolation in the firmware for threading with the 1 pulse per turn RapidTurn sensor) and normal quadrature encoders
Defeating the Re-flashing is easy. After you apply a pathpilot update, it will ask if you want to re-flash the Mesa and you just his escape.
The other issue, once he mod's the hal file, after ea update you have to copy the hal file back into the directory.
This really isn't too bad, you only have to do a few times a year when the updates come out, or just skip every few updates, doesn't really matter.
I think the benefit of having rigid tapping certainly outweighs the burden of the flash and hal issues.
yay! sensors finally arrived...back to getting the hardware squared away.
so no matter which avenue I follow (mesa vs parallel port), I'll be making changes to hal, ini, and post processor files. Seems to me if I follow the parallel port path I could at least eliminate having to manage a custom bitfile.
