586,103 active members*
3,859 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Amada Pega II Fanuc 6M. Y no find origin after X=0 Y=0 T=0 no move
Results 1 to 11 of 11
    Jul 2015
    14
    Hi everyone,
    This year we bought an old amada pega II with fanuc 6M. After very work we can do functional. From the first tests the procedure of find origin in y, x and t was perfect, however, from the last week and this week the control have problems for find the origin Y, after several times the machine find the Y origin. (I read other similar case in this forum), but, never return to origin after finish the program (no turn the light green on). However, today, we have the same problem, and after to have in point all the origin and begin a little program, the machine stop in middle of the program an put on the display X=0 Y=0 T=0. We check the machine and no saw problems.
    The light of top dead center are off, we operate manually the solenoid (because the keys jog incluiding punching don´t responded) for turn on the light. after of this, we push the jog keys and the number in Y and X change, but the table don´t move, the T = 0. We can´t do anything after of that.
    Please, any suggestions are welcome.
    Alfredo
    Aug 2011
    2517
    Re: Amada Pega II Fanuc 6M. Y no find origin after X=0 Y=0 T=0 no move
    check the origin switches are working. maybe one is faulty or stuck
    Jul 2015
    14
    Quote Originally Posted by fordav11 View Post
    Fordav11, I thing that isn´t the problem because the table are out of origin. When push the jog keys in manual state, the numbers in display change but, the table don´t move
    thanks
    Aug 2011
    2517
    possibly power supply problem or axis servo amp problem. maybe relay somewhere is faulty. could be several things.
    do you have any alarm?
    Jul 2015
    14
    Fordav11,
    no alarms. Today I will check newlly the different parts.
    thanks.
    Aug 2011
    2517
    assuming machine is working correctly, if readout moves but no table movement this would suggest machine lock is on? or maybe machine lock switch is faulty and not fully off?"
    Jul 2015
    14
    Hi Fordav11 and everyone.
    Here a little video where is possible see my problem with Pega II 304040 Fanuc control 6M.
    https://www.youtube.com/watch?v=76zOZ4zp_gw
    Please, I appreciate help.
    Thanks.
    Aug 2011
    2517
    video doesn't really help ;-)
    it still looks like machine lock is on.
    only other thing I can suggest is check to make sure MANUAL ABSOLUTE switch is on.
    also, before any actual movement can happen, it is usually necessary to zero return all axes on Fanuc 6 control.
    Jul 2015
    14
    Thanks for help Fordav11,
    do you can tell me how I can realize the "zero return all axes on Fanuc 6 control"? Is using the combination keys OT + Y´s and X´s in Retract position?
    Where is the Manual absolute switch? I think We dont touch, but, all is possible.
    Jul 2015
    14
    Fordav11,
    this weekend try to modify the value of MBK, but, I can't. I used this procedure: Punch Press/P002/Fanuc 6M Control | Amada America
    Because, when I check 100 position using DIAG key have binary: 10100101
    then, when try to change with PARAM key appear decimal: 128
    Is just calculate the decimal value of 00100101 (37)? For change the MLK
    Do you can give me a light.
    thanks,
    Alfredo
    Jul 2015
    14
    Finally, we can unblock the machine using the process with DIAG and PARAM keys. However, we have the proble with the Y Origin. We need probe several times for we can put in origen the Y axis.
    Any recomendation is welcome.
    Regards,
    Alfredo
  1. Pega 344 Amada Fanuc 6M electrical diagram
    By nguyenthanhthi in forum Fanuc
    Last Post: 02-07-2024, 10:12 AM
  2. Amada pega fanuc 04pc system error
    By cndcnd in forum Fanuc
    Last Post: 10-10-2018, 04:47 PM
  3. Replies: 2
    Last Post: 09-29-2015, 04:02 PM
  4. Replies: 10
    Last Post: 08-10-2011, 10:14 PM
