Haas 5C controller box (black box). Need parameter list for 5C controller box. It shows 14 parameters. I have HA5C but different.
I have an old model 5C and I'm looking for the parameter list also. Mine too only has 14 parameters. I'd like change the display and precision units from degrees and minutes to fractional degrees. If I come across the parameter list I'll post it.
Parameter 1: RELAY TIMING
Parameter 2: RELAY NO/NC
Parameter 3: HALF ACCELERATION AND SPEED
Parameter 4: HALF STEP MOTION
Parameter 5: DOUBLE REMOTE TRIGGER
Parameter 6: DISABLE CYCLE START
Parameter 7: MEMORY PROTECTION
Parameter 8: DISABLE REMOTE START
Parameter 9: WORM RATIO
Parameter 10: AUTO CYCLE START
Parameter 11: REVERSE MOTOR DIRECTION
Parameter 12: DISABLE CNC INTERFACE RELAY
Parameter 13: PROGRAM #
Parameter 14: REMOTE START DELAY
More details on the attached pdf.
