586,075 active members*
3,870 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > alarm 22 feedback system malfunction (1,0,&0021) after initializing MAZAK
Results 1 to 6 of 6
    Jul 2015
    started by QT-35 Mazak lathe with T-Plus controller ser# 130820 machine controller would not power up, we replaced QX141 and machine powered up, we lost parameters so initializing the machine, I copied from EEPROM, from what I remembered was never saved to and we did not have the org. parameter sheets that came with machine. that did not work and we had a long list of alarms and no tool locations, so we purchased the parameter sheets from Mazak for that ser# machine and initializing the machine again and input the parameters from the sheets, added the control options (I powered down and on the controller as instructed to on all instruction sheets), so it came a live with 8 alarms I cleared all but two the first and I feel the issue of second alarm is alarm# 22 feedback system malfunction (1,0,&0021) and the second alarm is # 121 over travel. any ideas what we can do to fix this and get machine running?
    Oct 2003
    321
    If you get the alarm on the monitor, look on your MDS ... In the electric cabinet .What you get on the Led of the Mds?
    Best regards
    [email protected]
    Quote Originally Posted by kimalpena View Post
    Jul 2015
    Re: alarm 22 feedback system malfunction (1,0,&0021) after initializing MAZAK
    SOLVED alarm 22
    Here they are:
    MDS-A-V2-3520 = FLASHING & SCROLLING F2 21 F1 21
    MDS-A-5P-300 = ONLY SCROLLING F6 E7 F6 E7
    MDS-C1-CV-300 = STAYING ON 6
    hope that helps I cant get anything from Mazak on this BUT Mitsubishi solved the #22 alarm (wrong parameters) , I still have the 121 alarm Over travel and if I press the OT release button I get a new alarm 226 Spindle Gear Shift Sensor Malfunction. So now need help on this new isssue
    Oct 2003
    321
    give me your mailadress.
    Best regards
    Mazak-user
    SOLVED alarm 22
    Here they are:
    I have the same Alarm Code 22 feedback system malfunction (1,0,&0021).
    What are the parameters that you have restored to solve the problem ? SP ?
    Thx for your help.
    Best regards
    Eric
    SOLVED alarm 22
    Here they are:
    Aug 2018
    porfavor puedes describir como es k mitsubishi resolvio el problema 22 de falta de realimentacion...les mandaste un correo o a traves de numero telefonico o ke¡?¡'---resulta q yo tengo el mismo problema y no he podido comunicarme con mitsubishi.
  1. ALARM # 22 FEEDBACK SYSTEM MALFUNCTION (1,0,&0043)
    By epordonez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-15-2013, 05:20 PM
  2. T32-3 System Malfunction Alarm 015 (2,9476)
    By Ben Colby in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-18-2012, 03:04 PM
  3. Mazak Nexus 200 - Battery Malfunction Alarm
    By bluechipmfgllc in forum CNC Machine Related Electronics
    Last Post: 09-28-2011, 03:58 AM
  4. Mazak T32-3 Alarm 015 System Malfunction
    By reillyeng in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-27-2011, 02:24 PM
