586,058 active members*
4,554 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Do you use Tool Kits - Kit Assistant
View Poll Results: Do you use Tool Kits - Kit Assistant, when programming jobs?
Voters
65. You may not vote on this poll
  • Yes I create Kits for every job I program
    9 13.85%
  • I sometimes create Tool Kits
    12 18.46%
  • I rarely create Tool Kits
    16 24.62%
  • What's a Tool Kit?
    28 43.08%
Results 1 to 19 of 19
    Mar 2006
    1013
    Do you use Tool Kits - Kit Assistant, when doing your jobs?
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Mar 2006
    1013
    So 20 people have look at this survey and only one person has responded. Come on guys! It's a simple question.
    Do you use Tool Kits?
    Somebody Push a Button. Let's get some interaction going here.
    Cheers to our one respondent for having the balls to say "I dont know what a Kit is"
    Mike Mattera
    Oct 2006
    7
    Hi Mike,
    What are you refering to when you say "tool Kits". Meaning what ?
    Dado
    Mar 2006
    1013
    Start - Programs - Edgecam - Toolkit Assistant.
    So I'll take that as a "No"
    Mike Mattera
    Oct 2006
    7
    This is my first post sense joining the CNC Zone. The question about tool kits drew a question mark. I write all my programs long hand. G-code.
    I started machining 42 years ago. I'm recouperating from a fall at work that broke my shoulder and tore my rotator cuff. I tripped over an air hose. I just had surgery last Wednesday to repair the damaged Cuff. I'm on the mend now and plan to return to work after the Holidays.
    The shortage of machinists and our work load has caused our company to build a plant in China. Companies all around me here in Minnesota are having difficulties in hiring competant machnists. So, when I retire in a few years, I'll buy some machinig centers and grab some of that work.
    I'll hire a few young people the secret's learned in 45 years of machining. I enjoy teaching . They can learn from me and get paid as well. I'd like to start a production teaching school. Very small time of course. I would enjoy that.
    I have to teach myself Cad Cam. The company I work for doesn't believe in any on the job training of such things as using Cad Cam. That's the engineers job they say. Oh well, I'll teach myself off the job.
    Be thankful if you have a company that will teach on the job.
    Apr 2006
    11
    Wink Tool Kits.
    Just to let you know where I stand on toolkits.
    I have been using Edgecam for 9 years now and have never used a tool kit. I am sure it is a useful tool if you are doing similar components but in a small subcontract workshop you never get a spare minute to set these things up.
    Even my toolstore is incomplete! Now that I have started using some of the new adaptive postprocessors in version 11 with machine graphics, I am having to go through my entire toolstore to add gauge height and holder information that was not used before. Very tedious but well worth it when you can see whether or not you have a collision with the 4th axis.
    John
    Mar 2006
    1013
    Hi John,
    I know whet you mean. I just finished a new training cd for Edgecam and one of the most important things was to get a complete set of Drills, & Counter bores in 1/32 (and some of the more important 1/64) sizes. Making sure they have tool holders and the proper gauge length.
    It's now included with the training CD along with a Fanuc compatible 3X vertical mill post, for machie simulation.
    Mike Mattera
    Jun 2003
    73
    Tool kits are great for assigning turret positions for specific tools that stay in the same location in machining centers. You can start the basic tool kit for a specific machine and then copy it for a certain job if you're adding more tools to it.
    You can actually make a job after you program the part and it takes at most 1 minute and the time it saves for documentation and set/ups can save you a ton in the end.
    Mike W.
    Nov 2004
    320
    never used it
    only do 1 off stuff and have enough other things to do
    mike
    Nov 2003
    459
    Too bad the Polls are not very effective...
    Quote Originally Posted by Mike Mattera View Post
    Mike,
    I share your disappointment...
    Now you have 25 responses in 880 views!
    What % participation is that less than .03?
    Or, there are so few Edgecam users who "do" use toolkits...
    What do you think?
    Personally, I don't or didn't...
    I am using UG NX4 now, and I don't use it's Tool library either.
    I created my own system using Excel and Macro Express to import my data...
    I think it's cool...
    Scott_bob
    Mar 2006
    1013
    Well since Tool Kits are tied into the HTML setup sheets/Job reports, I can assume many of you are not using Job Reports either.
    So what is a Tool Kit?
    A pre selected list of tools for use on a particular part. You can select your tools, set Tool #'s and offsets for a particular job. The Kit name will usually be the same as the Job (NC) name, but it doesent have to be.
    If you go to...
    Start - Programs - Edgecam - Tool Kit Assistant.
    You will open the Edgecam Tool Kit Assistant. In here you can Create a new Tool Kit (upper right). You should enter some general information about the Job. This same information can also be accessed thru the Job Manager.
    Press OK to accept the new job.
    At this point your looking at Jobs/Kits (Left window) and Tools (right window). Grab a tool from the right side and drag ot over to the job name (you just created) on the left side. Select all the tools you'll need for the job.
    Exit the Tool Kit Assistant and go into Edgecam.
    In Edgecam: When switching to Mfg Mode, you are asked for a Sequence name, Discipline (Mill/Turn) and Machine Tool (post). Select the Tab "Job Data". Browse the Job name and pick your new Tool Kit. Any other information you filled in regarding the job will populate the rest of the fields. OK to accept this.
    Now when you do your toolpaths and select "Browse ToolStore" it will display the tools from your kit. All of the tool numbers and offsets already defined.
    Mike Mattera
    Nov 2005
    1468
    Still none the wiser....
    I manualy create my G Code or use Dolpin CAM to post process a CAD file imported from Autocad. I also use my own program written in VBasic and converted to EXE to generate G Code... erm are any of them tool kits or do you mean toolkits like spanners, hacksaws and big hammers to hit the machine when it's bad?
    *scratches head*
    I love deadlines- I like the whooshing sound they make as they fly by.
    Nov 2004
    320
    iman carrot
    why dont you use dolphin to generate your code?
    Nov 2005
    1468
    I do for my Turret Mill, but for my Diamond Turning lathe it's a bit more complicated, the equation I use too complicated for Dolphin to handle:
    f(x)= [(x^2/R)/(1+SQR(1-(K+1)-(X^2/R^2)))]+ A4^4 + A6^6 +A8^8... etc
    R= radius of curvature which can be anything (and convex or concave),
    K= Conic coeffiecient, 0 for a sphere, -1 for parabola between -1 and 0 for a prolate spheroid (small end of an elipse) and >0 for oblate spheroid (large end)
    X= Distance from centre (X0) incremented in 0.005mm.
    A4-A10= Aspheric co- efficients which modify the sag
    Put into this mix the fact that stoopid designers sometimes use the Conic Constant instead of Co-efficient and sometimes get the signs of the Radius and/or aspheric coefficients wrong and you can see my headache lol.
    Nov 2004
    320
    oh ....right .....
    May 2005
    11
    Hi Mike,
    I've been using pathtrace for about 17 years give or take and so i've seen all changes most for the good i might add, at moment im staying on 7.75 as i like to stay behind a bit as before ive rushed in and up-revisioned and then found that alot of surfacing done in previous revision has been re-pathed with unexpected results. and once saved in new version theres no going back, by the way we do do alot of 3d work.
    i've looked at latest editions and to be quite frank i think software guys need to have a working,well experienced,shopfloor person to look over what they are doing.
    An example- old facemill command- put in a few parameters and 3 mouse clicks later done
    New facemill command- put in lots of parameters, create boundaries, then mess about with until paths are what you want.
    Same with old surface lace command -you knew what it was going to do but with new surface commands software guys seem to be trying to put it all on one tab with all commands on it.
    Now i know that there still there as "superceeded" but for how long.
    Looking at amount of work that we do on edgecam(we have got approx 2500 ppf files each with at least 4-6 programs.
    I did the post compiler course some years ago and over years have refined posts so that the guys on shopfloor do not do any editing at all, even speeds,feeds also theres no single blocking(whos got time for that on 200,000 line programs).By the way thats not including our turning ppf's
    Any way back to original question "Do i use tool kits"
    Answer "no"
    I can see that they would be useful if you had a lot of common parts but we tent to use about 8 pockets in all our machines with same useful tools and then when we call these tools from database they are defaulted to that pocket.
    When i first saw pathtraces tool database i had a little chuckle put it to one side and started afresh, everytime a new tool is used it is created 1st so our tool data base has in excess of 8000 tools (probabley 40% of this is 1mm-20mm drills in .1mm inc. and same with reamers and all types of taps threadmills)
    But inspite of my moans edgecam still up there at the top and believe me i've programmed on a more than a few other cam systems.
    Regards
    Nov 2007
    7
    I never try that before
    Dec 2017
    34
    Re: Do you use Tool Kits - Kit Assistant
    Swarfmaker,
    You know you can go back and find all of the old commands, put them up on the bar and use them instead. I still use the old thread mill command. It just works better than the new one.
    But I digress.
    I use tool kits, but not in the way your poll suggests. I found the best way to use tool kits is by machine. You can create a tool kit that sets up your turret. Assign the tool numbers for each pocket, and then never worry about selecting a tool you may not even have.
    It works great.
    http://www.heavymetalcnc.com
    Sep 2011
    9
    I tried to use them it ended up being a complete waste of time for a bunch of incomplete information. I posted a similliar question on edgecam's help forum and got the feeling it not worth the effort.
  1. Post assistant - machine simulation
    By Daudi in forum EdgeCam
    Last Post: 03-15-2014, 11:46 AM
  2. Edgecam Technology Assistant
    By turningboy1979 in forum EdgeCam
    Last Post: 02-08-2012, 05:23 AM
  3. CHICAGO, IL.. Looking for an assistant to CNC Machinists...
    By tomekeuro85 in forum Employment Opportunity
    Last Post: 08-13-2008, 04:08 AM
  4. Electronic Assistant: Calculator
    By slp_prlzys in forum CNC Machine Related Electronics
    Last Post: 01-01-2006, 11:37 PM
  5. Replies: 19
    Last Post: 12-24-2005, 07:12 AM
