Hi all,
I went out on a limb and purchased a 700*500mm 60W CO2 chinese laser cutter.
Was well packaged and easy to get up and running only took about an hour.
Once the machine was setup i thought i would embark on setting the lens focus etc. I placed a piece of mdf down and set the focal distance using the orange spacer provided with the machine. I fired a pulse and it burns a fine dot approx 0.5mm. My first question is.. does this mean my mirrors etc are well aligned?
My second question is i have tried vutting through some 5mm MDF and even at 90% 1mm/sec i cant cut through. Only way i can really get through is by doing multiple passes. Should i be able to get through cleanly in one pass with a 60W laser?
Thank you for any input you might have.
