586,069 active members*
3,903 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Only MeshCam has option to rough and finish?
Results 1 to 6 of 6
    Feb 2013
    27
    Is Meshcam the only real alternative (nothing cheaper), when needing to rough in with one tool, then finish with another, without running 2 gcode files on the same piece?
    Thanx, Alan
    Apr 2004
    5737
    Re: Only MeshCam has option to rough and finish?
    Are you sure that's the way it works? Usually, if you don't have dual spindles or an automatic toolchanger, you need to run one program to the end with the roughing tool, then rezero the Z axis for a new tool and run a second G-code file for the finishing pass. And yes, there are alternatives.
    Andrew Werby
    Website
    Feb 2013
    27
    I am new to this and assumed that meshCam would generate code that would pause after roughing, so I could then change tools, re-zero, then restart the gcode.
    Feb 2013
    27
    Feb 2013
    27
    PlanetCNC Mk3 (9 axis) seems to be a possibility.
    Anyone out there using it?
    35538
    Quote Originally Posted by estes53 View Post
    Thanx, Alan
    Any CAM program should have that capability. Except maybe some free ones.
    Planet CNC is a machine controller, not a ,CAM program, although it may have some CAM capabilities.
  1. Rough Start Outside Workpiece Option?
    By suzukirmz in forum CamWorks
    Last Post: 04-13-2018, 11:42 AM
  2. info on how zero and do rough finish passes...
    By airbrush in forum BobCad-Cam
    Last Post: 05-30-2015, 08:04 AM
  3. Problems with rough finish
    By 44-henry in forum Tormach Personal CNC Mill
    Last Post: 06-02-2009, 06:43 PM
  4. How to rough/finish threadmill in MCX?
    By John_B in forum Mastercam
    Last Post: 07-27-2008, 04:25 PM
  5. Very rough finish when turning 6061-T6 ... why?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2008, 11:24 PM
