587,067 active members*
3,774 visitors online*
Results 1 to 13 of 13
    Jul 2006
    68
    textured ABS sheet source?
    Does anybody know where to buy sheets of ABS that are textured on one side?
    Thanks!
    Aug 2004
    2849
    rplastics.com has sheets....even Amazon.com has 1'x2' sheets....search the internet for Textured ABS sheets. I suspect that McMaster Carr also has the product.
    Oct 2006
    125
    My impression is that haircell textured-on-one-side ABS is very common; some places sell only that and have to special order smooth-on-both-sides ABS.
    I'd think you could get it from your local plastics supply place.
    Unless you're talking about more interesting textures than haircell...? If so, please report back on what you find; I'm interested too.
    Jul 2006
    68
    Thanks, guys. If McMaster-Carr has it, I couldn't find it with the search words I used. I buy from them regularly, so I checked them first.
    rplastics.com does have what I need, so if I can't find something in SoCal, I'll use them. I need more than just 1x2' sheets.
    Aug 2004
    2849
    you search for "ABS Sheets", but it looks like they don't have the textured...just clear, opague, and translucent.
    Jul 2006
    68
    Yeah, that's all I found...they have an excellent search system... but I'm only interested in black with texture on one side.
    Oct 2006
    49
    Can supply from India
    Quote Originally Posted by tenaja View Post
    I am a plastics consultant and can supply from India sizes 2440x 1220 mm( 48"x96") and even longer, if there is a good volume order.
    What thickness you need and color? Pls specify. Write back to my email ID [email protected]
    Chan Luci, Techie
    www.custompartsonline.com
    Jul 2006
    68
    I don't need enough to bother importing it, that's for sure!!!
    Jul 2006
    68
    Ok, I ordered from rplastics.com , and a week later they still hadn't shipped it, so I cancelled the order. If they had contacted me to let me know it would be so long I would have been ok--but a week delay in shipping with no notice is just bad customer service in my field.
    I ordered it from Port Plastics, and had it two days later. (To rp's credit, they had 2x4' sheets, whereas Port's were 4x8', unless you wanted to pay for a cut fee, but that just delayed shipment.) The material that both suppliers had was "haircell", and it's butt-ugly. The texture is far too coarse for what I want.
    I've seen material with a coarse "edm finish"... anybody know a source--or brand to request-- for that?
    Thanks again!!!
    Nov 2006
    25
    Most of the haircell I have used is not as rough as your post would seem to indicate. The exception is reground material which has a rougher pattern.
    There are a few standard ABS textures.
    Uniroyal Div of Spartech Plastics usually has warehouse stock. In addition to haicell, Royalite ABS ( Uniroyal brand ) also came in "level haircell' ( smoother ) and "Falmouth" which is similar to the texture on computers.
    But you have to buy from a distributor. Any large plastics distributor should be able to give you information. Most distributors only stock black and white haircell.
    http://www.spartech.com/plastics/abs_sheet.html
    Have you looked at Kydex ( acrylic - PVC alloy )? It's more expensive than ABS bbut the hiarcell is fairly smooth.
    If you only need a small amount of material and can't find what you want maybe you could try local vacuum formers. They might have extra sheets from a run.
    HTH
    Nov 2007
    Hello, Tenaja!
    I'm a new comer here.
    If you're still working with ABS sheet, we are professional produce of it in China, textured or embossed. With printing patern or without. Both available.
    For more info., you can send me a mail to:[email protected]
    Sky Good Tech. Industrial Co., Ltd.
    Producer of (ABS, PC, BOPP, OPP FILM, SHEET, PACKAGING BAG. SELL INTERNATIONALLY)
    Sep 2007
    42
    Quote Originally Posted by casung life View Post
    Hello, Tenaja!
    Hey, I'm interested. However, I only need small quantities. Right now, I could use 10 sheets of 2x4 .125" haircell black abs. What is the total cost, including shipping, and what is the lead-time?
    Thanks,
    Doug
    Try ABS Sheet and Rod - Plastic Materials | Industrial Plastic Supply, Inc.. They have both textured or Hair Cell material as well as machine grade in white and black.
