586,414 active members*
3,217 visitors online*
    Mar 2011
    68
    Modify Postprocessor
    Hello,
    I have a postprocessor and I want to make some modifications:
    1.When I create new origin i have MAC 1(1- Position), then MAC 2(1-Position), and so on.
    When I generate the Gcode, it generate G54, G55, and so on depends of the MAC number.
    The problem is that I want even if I generate an operation in MAC2 to generate G54.
    BUT, if I have many operations with different MAC number to have generatet de gcode in G54, G55 and so on.
    The problem came when I have 3 or more Mac number, like MAC3 and MAC4, if I combine operations from this 2, I want to generate G54 and G55 not G56 and G57, and also if I have operations like:
    contour20 in MAC3
    contour 30 in MAC4
    Contour 21 in MAC3, there must be generated something like:
    G54
    G55
    G54
    , also to temember the number of mac.
    For origin I have this writed in my post:
    @home_number
    if salva_origine <> home_number
    origine_alta = 1
    endif
    gcode = 53 + home_number ------->>>>here if I put only G54, the always will be generated only G54.
    {nb'G' gcode}
    if informazioni eq TRUE then
    {' ( - CAMBIO ORIGINE - )'}
    endif
    salva_origine = home_number
    procedura = "home_number"
    endp
    Is there any possibility to can change the post for making what I want?
    I can be also available on skype: claudiu221289.
    I also attached the gpp file with .txt extension.
    I can give more informations if something is not understandable.
    Thanks and hope somebody can resolve this.
    Have a nice day.
    Attached Files Attached Files
    Oct 2013
    153
    Re: Modify Postprocessor
    If I understand correctly you want to make operations in different positions but in one coordinate system! Like G54 but in different positions!
    You can do this by creating one coordinate system with different positions like MAC-1 position-1 and MAC-1 position-2 so on !
    Mar 2011
    68
    Quote Originally Posted by imachining-6061 View Post
    This is also a good idea, but what can I do to solidcam create automaticaly MAC1 position 1 and MAC1 position 2, every time, it create MAC1 position 1, MAC2 position 1.
    I tryed to modify dhe 2 in 1, but when I select a face it goes back to 2, and I must change again to 1, this mean time and a lot of clicks.
    I have some postprocessors do M1 P1 and M1P2, but this one that I need always have M1P1 and M2P1....
    Is there any setting that I can change?
    First there was another idea, that sem you do not understant.
    I can explain better on skype or facebook chat.
    If you want, I can send you a PM with my FB or Skype.
    Thanks in advance.
    Apr 2014
    24
    Hello,
    it seems to be the problem of your post, I can make this prefect post to you, contact me by email, [email protected].
    Jan 2013
    73
    Good day, do you have 4-axis postprocessor for sinumerik 810M?
  1. To modify or buy new?
    By cstroke in forum DynaTorch
    Last Post: 02-07-2019, 12:51 AM
  2. MPMaster Modify - G17
    By charger19690 in forum Post Processors for MC
    Last Post: 07-27-2010, 02:27 AM
  3. Modify STL in SW
    By DIFF OVER in forum Solidworks
    Last Post: 03-11-2009, 01:54 AM
  4. how can i modify the post?
    By ahmedsamy_81 in forum Post Processors for MC
    Last Post: 07-16-2006, 08:25 PM
