586,363 active members*
3,217 visitors online*
    Dec 2007
    18
    Question Problem - WinCNC Plasma restart
    Hi all,
    I have a customer that has WinCNC on his Hidef Plasma cutter, It works very well but has one small problem....
    If they lose the arc and have to restart, the torch first goes up to the top limit and then as it goes down to the plate it starts to strike all the way until it touches the plate. Is there any way to delay the start signal or only make it strike when it reaches a certain Z position, as the high frequency eventually damages the THC?
    Thank you in advance :-)
    Regards
    Steve
    May 2009
    281
    Re: Problem - WinCNC Plasma restart
    look through the wincnc file, and look for the calls to the macros used to start the torch, the control code should be there some where, make sure you save the original if you try any changes, the same goes for any macros you might try to adjust.
  1. Wincnc restart command
    By rcbahn in forum WinCnc
    Last Post: 11-18-2010, 08:56 PM
  2. WinCNC Problem?
    By Absolute Steve in forum G-Code Programing
    Last Post: 04-17-2009, 11:17 PM
  3. wincnc problem need help!!!!! Please...
    By dsgnkrft in forum WinCnc
    Last Post: 12-19-2007, 01:18 AM
  4. mach3 plasma restart mid-job?
    By johnt in forum Mach Plasma / Laser
    Last Post: 12-04-2007, 05:59 AM
  5. Controller Restart problem!
    By VB IT in forum CNC Machine Related Electronics
    Last Post: 02-25-2007, 09:48 AM
