586,655 active members*
2,800 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i-TD tool change recovery stuck
    Feb 2015
    4
    Machine: HONOR VL-125CM
    Confrol: FANUC 0i-TD
    Alarm: EX1995 - Magazine Change Before Dataetc
    While I was out on vacation last week, an inexperienced operator made a mistake during a tool change operation. Instead of MDI- M6 T0900, he input M6 T909. The ram moved to the ATC, dropped off the current tool, rapid up to rotate the ATC and stopped there.
    I've tried to do the usual Tool Change Recovery by going into system>pmcmnt>data and matching line D440 and D445 to the same number. This has not fixed the issue.
    The machine believes it has tool 9 in the spindle, tool 9 is actually in its home in the ATC.
    I'm stuck and can't figure out where to go from here. Please help!
    Jun 2004
    511
    Re: Fanuc 0i-TD tool change recovery stuck
    It sounds like you are on the right track with the D values. Not knowing your machine, I cant say what Ds are what, but that should be where the tool numbers go. If you have a print out of the PMC in the ladder book it will spell out what Ds are assigned to what.
  1. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  2. SMTC arm stuck, recovery does not work.
    By l u k e in forum Haas Mills
    Last Post: 01-08-2013, 12:09 AM
  3. Fanuc 18-T Tool Change Recovery
    By TurnMyWorkpiece in forum Fanuc
    Last Post: 07-19-2012, 06:56 PM
  4. tool change stuck!!!!!!!!
    By jay_dizzle in forum Fanuc
    Last Post: 12-21-2010, 03:49 PM
  5. Tool Change Recovery VF3 Umbrella
    By cncmaintenance in forum Haas Mills
    Last Post: 11-07-2008, 07:05 PM
