586,080 active members*
3,791 visitors online*
IndustryArena Forum > CAM Software > Vectric > Change the depth of a cut over distance???
    Dec 2010
    313
    Question Change the depth of a cut over distance???
    Hello,
    I'd like to gradually change the cut depth of a single line, say for example I start at 0 then over the span of 200mm step into the work 4mm. Just make a Gradient of 4mm over 200mm if possible.
    Can I do this using Vector? If so How?
    Thanks in advance for your help,
    Rob
    Re: Change the depth of a cut over distance???
    Try the Fluting Tool.
    Dec 2010
    313
    Thank you! I'll give it a shot.
  1. retract distance and go to zero.
    By FoxCNC1 in forum Aspire
    Last Post: 02-14-2014, 07:05 PM
  2. Does Microstepping value change distance traveled?
    By Fastest1 in forum Stepper Motors / Drives
    Last Post: 03-09-2012, 04:40 PM
  3. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  4. Distance is off..Set a Ratio?
    By Ezra in forum Joes CNC Model 2006
    Last Post: 11-14-2010, 06:43 PM
  5. Bearing distance
    By pyrojon in forum DIY CNC Router Table Machines
    Last Post: 05-23-2005, 01:51 PM
