586,108 active members*
3,071 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Milling wood on a VMC designed for metal
    Jul 2015
    4
    Does anyone have any experience milling wood on a machine designed for metal? I've never done any woodwork, what range of RPM is wood milling done in? I assume i'll need tooling designed specifically for woodwork? The main obvious things i can think of is to obviously run it without coolant, set up a vacuum, cover the coolant drains. Are there any other issues i could run into?
    Dec 2006
    108
    Re: Milling wood on a VMC designed for metal
    I was able to machine brass, stainless, walnut, ash, and white maple chess pieces on a Grizzly G0602 lathe using the same bit that I ground from a parting blade. The wood pieces had to be redesigned slightly to avoid the thin sections but other than that it worked well. I did not run the lathe much faster than when I ran the brass pieces. I also did not to run the lathe at maximum speed as I was concerned with excess wear though it may have been unfounded.
    Best Regards.
    Carl
    Feb 2011
    423
    Have you looked at the Gwizzard software? It is a speed and feedrate calculator. I seem to recall that Bob has some figures calculated for wood.
    Think they offer a free demo as well.
  1. Wood or metal
    By cncman2 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2013, 04:29 AM
  2. Need 16"x16" Wood Milling / Metal Engraving CNC Machine
    By jsu1995 in forum Want To Buy...Need help!
    Last Post: 02-28-2013, 02:40 PM
  3. OMNI Designed For Precision CNC Wood Router
    By omnicnc in forum Omni CNC
    Last Post: 11-29-2012, 07:01 AM
  4. Hardware store designed , all metal, Desktop wide router for review
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 02-10-2009, 02:18 AM
  5. RFQ-Need simple metal bracket designed and machined
    By topazdave in forum Employment Opportunity
    Last Post: 12-07-2005, 12:10 AM
