586,123 active members*
3,140 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Programming/OSP 5020L
Results 1 to 7 of 7
    May 2015
    35
    How do I ensure that my tool doesn't crash into my live center when I start my program? I program with the IGF and not G-Code.
    May 2015
    35
    Re: Programming/OSP 5020L
    Or maybe I should ask, how do I set the relay points to go around the center?
    Aug 2011
    2517
    the barrier setting procedure is in the operation manual.
    programming with IGF doesn't mean your tools will crash, or not crash. if you set the work zero correctly and program it correctly then the tool shouldn't be anywhere near the center.
    setting the safety barrier can help to save your center, but the correct thing to do is learn how to use the machine properly and how to program it correctly.
    if you have the barrier set and the tool tries to hit the center it will save it, but the machine will not be making parts so you will still be no-where.
    reading the operation and programming manuals in full and learning proper operation including running in single block with slow rapid for the 1st part will get you further.
    May 2015
    35
    Quote Originally Posted by fordav11 View Post
    I found the section in the operation manual for setting the tailstock barrier and did that. However, the tool is still going to crash. What am I missing? Tool interference area maybe? Entering an M21? I only know how to program in IGF.
    May 2015
    35
    Where are you "Okuma Wiz"? I know you can help me out here.
    Apr 2009
    1262
    Now you coaxed me out of the shadows...
    The IGF has a parameter that deals with the approach direction. It is built just for that purpose. I do not have a 5020 IGF book, but if you take a look in the IGF parameters you should be able to find it. It will force it to approach in Z first and then approach in X rather than simultaneously. The other thing to do is to adjust your Variable limit on the machine so that it retracts in Z no more than is needed to cut the part. This will make your approaches safe and not "go through" the tailstock.
    Best regards,
    May 2015
    35
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Thanks Okuma Wiz! I was able to go into the IGF parameters and describe my tailstock to the machine. However, I found that the easiest way to clear the tailstock is by changing the Z location of each tool index location. It shortens the cycle time too. I'm learning something new each time I run the machine. Thanks again!
  1. OKUMA OSP 5020L
    By nikolamkd in forum Okuma
    Last Post: 01-06-2023, 07:58 AM
  2. okuma lr 15m osp 5020l
    By Sheena on in forum Okuma
    Last Post: 08-06-2013, 11:15 AM
  3. LB 15II osp 5020L
    By MCR-B II in forum Okuma
    Last Post: 10-19-2012, 05:19 PM
  4. 5020L Not booting
    By JasonMiller in forum Okuma
    Last Post: 05-13-2010, 06:11 AM
  5. OSP 5020L
    By MKATool in forum Okuma
    Last Post: 04-06-2008, 08:08 PM
