I am looking for a way to "replace all" text with ascending numbers to help with some editing after posting. I am aware that gibbs has an option to number all of the lines built in, but I find that the way it outputs the numbering is entirely too cluttered. I don't want each line numbered, I only want the operations numbered. Unless I'm missing out on a way to only number operations in ascending number?
For example:
I am trying to find all lines that start with the letter "N" and replace them with N1, N2, N3... so on and so forth.
Currently I am using the "Replace All" option in notepad to simply replace comments with certain codes that I need for the machine I am running. It's sort of a posting issue work-around that I'm working with.
Can anyone point me in the right direction as this would cut A LOT of time out of my programming.
