586,076 active members*
3,912 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > can anyone help with heidenhain 2500 control parameters?
Results 1 to 17 of 17
    Nov 2006
    251
    I have a brigeport interact 1 mk 2 milling machine with a heidenhain 2500 controll and the back up battery went flat while on holidays unfotunately we had no parremeters sheet with machine and lost every thing the nc software number is 243000/12 plc software number is 250144/ 03 could some one please assist me with parremeter sheets if possible thank you.
    Nov 2006
    925
    You can download a technical manual for the control from www.heidenhain.de
    This will explain what each parameter does and the range it can be set within.If you have some experience of machine controls it is possible with a bit of thought to get the machine running and carefully go through the movements and adjust the parameters to suit your machine.The plc parameters on this machine should be on eprom so you should not have lost them.If you have,the manual explains how to reload them from the eprom.The Bridgeport does not use a lot of parameters so it will take some time but not as bad as some machines I have worked on.
    Sep 2006
    21
    if you give me your e-mail I would be glad to e-mail them to you or I can fax them to you.
    BlackPalm
    Nov 2006
    251
    help from black palm on tnc 2500 parremeters
    blackpalm yor help on tnc 2500 control with brigeport interact 1 mk11 milling machine parameter listing would be most help full my email address is [email protected]
    Mar 2007
    8
    Bridgeport II Intract 4 with Heidenhain TNC 2500
    Dear Friends;
    I have a machine needs for Parameter
    My Machine details are:
    Bridgeport Series II
    Intract 4
    Control: Heidenhain TNC 2500
    Serial No.: 616901290E/04881
    I have lost the machine Parameter, and also I need:
    - Machine Parameter
    - NC 243009 12
    - PPLC 250144 03
    Thank you very much for your kind attention & waiting for your replay.
    Best regards
    Mahmoud Elhosseiny
    E-mail: [email protected]
    Feb 2007
    37
    I also have the same machine. I can send you my parameters also if someone could tell me how to backup the parameters from my machine first. Machine is connected to a computer via serial cable.
    Regards,
    Pali
    Nov 2004
    3028
    to back up parameters.
    MOD key to CODE=
    Code= 95148 This displays the parameters.
    EXT key. It will ask: read in parameters?
    NOENT key and they get dumped out.
    George
    Feb 2007
    37
    George,
    Thanks again for your support. I will export the parameter and send it to you Greg B.
    Pali
    Sep 2008
    67
    machine nam :bridjport
    heidenhain TNC2500
    NC soft 243002 12
    PLC soft 250144 08
    the battery,wiring and all is good bat a green LED in motherboard flaching
    If entered all the parameters by hands,when i restart the machine,there is no parameter
    thanks
    Nov 2006
    925
    What do you do when you enter the last parameter?
    Are you entering the parameters manually?
    Do you mean that the control asks you to re-enter the parameters after a shutdown or right after you have entered the last one?
    If it works ok until you shut down,it is usually corrosion on the inner battery holder terminal.
    Mark.
    Aug 2011
    Hi
    Could you please e-mail me the machine parameter.
    Appreciated what you doing
    My e-mail: [email protected]
    Regards
    Feb 2007
    37
    Here is a link to a backup of my parameters. The machine is Interact 1 MK II with TNC2500 Control.
    Click here to download.
    Pali
    Aug 2011
    Quote Originally Posted by palikalsi View Post
    Pali
    Thanks a lot Pali
    Jun 2011
    61
    Smile Heidenhain TNC 2500 Parameters
    If anybody needs a full set of the Heidenhain TNC 2500 parameters I have now got them , and those that dont know yet , if you have a Heidenhain from the 90,s then look after your batteries !!!!!
    1121
    why not post them on the heidenhain parameter thread
    Oct 2012
    I am looking for parameter list for Heidenhain 2500B. Any help would be appreciated. Thanks.
    Jan 2013
    7
    Is there an updated link to this?
    I'm actually looking for parameters for:
    NC 243000 12
    PLC 250144 03
    Thank you,
    Pali
