586,119 active members*
3,646 visitors online*
    May 2015
    Angry New 64 bit computer....need help
    I bought an old DynaCNC table with a Dyna1000-THC controller (didn't know they were defunct) and was just getting it kind of figured out, when the 10 year old computer decided to fry itself.
    I did what any newbie would have done and bought a new computer. Now for my problems....
    Mach 3 won't run on 64 bit, so I bought Mach4.....Apparently Mach doesn't really like to pay anyone to offer tech support to its customers. It appears that I need some sort of plugin and need to setup the software to run the control box.
    Have any of you been through this and can lead me to a manual that will give me some direction. I am very green with this stuff.
    I am about $10,000 into this adventure so far, I am frustrated to say the least.:drowning:
    Oct 2013
    15
    Re: New 64 bit computer....need help
    I have Mach3 installed and running on my development PC which is windows 7 64bit, however I have not connected to a CNC controller. So I guess some 64bit systems it may work.
    This might be a bit of a pain to do (and may not work) but you could try running an emulator so the 64 bit pretends it is a 32 bit PC:
    From Microsoft: "WOW64 is the x86 emulator that allows 32-bit Windows-based applications to run seamlessly on 64-bit Windows"
    https://msdn.microsoft.com/en-us/lib...=vs.85%29.aspx
    Or you could try running in XP mode (I have used this to run programs that would not run on WIN7):
    Install and use Windows XP Mode in Windows 7
    I wouldn't think you could damage your PC port or controller, but I'm not 100% sure (maybe 95% you will be ok) so be careful (don't blame me if something goes bang).
    - - - Updated - - -
    https://msdn.microsoft.com/en-us/library/windows/desktop/aa384249%28v=vs.85%29.aspx
    http://windows.microsoft.com/en-NZ/windows7/install-and-use-windows-xp-mode-in-windows-7
    Jun 2008
    562
    As long as you have the needed parallel ports, give XP mode a try with Mach3. If that doesn't work, how about downgrading the computer to a Win 7 32 bit operating system.
    You could try the forum here: Mach4 General Discussion
    I think the Dyna 1000 was made by Tom Caudle at Candcnc, you could try them: Home
    Good Luck
    Mike
    Neither Mach3 or Mach4 can use a parallel port in a 64 bit version of windows.
    They will both work fine, however, if you use a motion controller.
    Not sure if your THC will work properly with a motion controller, though.
    You're best option is to probably by an old Pentium 4 PC with XP on it from Ebay, or Craigslist. Shouldn't be more than about $100
    May 2007
    111
    Still needing help on your dynacnc table?
  1. Replies: 8
    Last Post: 08-20-2014, 07:16 AM
  2. from one computer to another
    By helpmeout in forum Vectric
    Last Post: 12-11-2012, 02:30 PM
  3. what computer for IH cnc
    By RACER99 in forum Benchtop Machines
    Last Post: 03-06-2011, 11:52 AM
  4. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
