Re: Shell Mill Cutter v/s Shear Hog Insert Mill
Originally Posted by
mountaindew
You would need to use one of their tts conversion collars epoxied to shank . Only other way is to mount in a er32 collet and this could produce a stacked tool run-out and or reduce z height.
I got a kick out of this video a while back thinking he removed more metal in 2 minutes then I did on a complete project I did. This made a big pocket in a chunk of material and I made a couple soft jaw tool makers vises complete! I guess someday I will need to plow out that much material, right now I can machine stuff all day and end up with a handful of parts and a little swarf to clean up.
I made some collars for 3/4 inch straight shank tools like a Shear Hog. I made my tool flanges from 6061 aluminum duplicated the tool flange on a TTS holder. I made the hole .002 to .003 smaller than the shank of the tool, then I will heat the flange with a torch until it fits on the shank of the tool, slide it down to where I want it and squirt it with a spray bottle to cool it. With .002 or .003 shrink fit, there's no way it's going to move. Now it works just like any other TTS holder.
I have a 1 inch Shear Hog, and I'll guarantee you, I can remove more material, faster than one can with the Super Fly fly cutter, AND I'll get a better finish.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
