586,111 active members*
3,724 visitors online*
    Nov 2013
    25
    ALL in one electronics?
    Is there any reason one couldn't put all the electronic components in one metal cabinet?
    Mobo
    HDD
    Power supply /pc
    Bob
    Drivers
    Power supply /controller
    Thanks, Carl
    24221
    Re: ALL in one electronics?
    None, if done properly.
    Al.
    Albert E.
    May 2014
    182
    I was looking at using this guy right here for a PC included in my electronics box (coupled with a USB smoothstepper):
    Black ECS LIVA 2GB DDR3L RAM installed 32GB eMMC Storage - Newegg.com
    Mean Well USA - RS-25-5 - RS Series Switching Panel Mount Enclosed 88-264V In 5V@5A AC-DC Power Supply - Allied Electronics
    (or the medical grade variant)
    I would never have a monitor/keyboard/mouse hooked up to it - I would just remote into the computer and control everything from a remote laptop or computer.
    Pros:
    Super low power consumption -
    Use a single 5V power supply and distribute it to your smoothstepper, BOB and AIO PC linked above. This gets rid of the 12V power supplies needed for most PC components. 24V/5V power supplies are very typical as well.
    Linux distributions would probably work (linuxCNC)
    Cons:
    It would force you to use windows 8 - which has *some* compatibility issues. Not a game changer though
    Possible interference of signals if you don't adhere to some rules in your electronics box design
    Jan 2008
    241
    I just finished building this and its working great!
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    Jan 2009
    334
    Quote Originally Posted by Cayenne View Post
    Mobo
    HDD
    Power supply /pc
    Bob
    Drivers
    Thanks, Carl
    I have been working on a design based on the iBOB2 and Gizmosphere 1. I hope in a few weeks to have video uploaded of a converted Denford Novaturn lathe with Yaskawa SGDA 01AS Servos. The Dimensions of the GQ1 are Width 6.79", Height 6.61" and Depth 10.29". It has 6 axis of +- 10V analog servo control and all IO are available on 2 DB50 and 1 DB 25 connector. The RJ45 is for a pendant interface. It could also be made for step and direction. I prefer true closed loop control. I plan on selling the iBOB2 for anyone who wishes to make a ultra small CNC controller or place the complete controller within a small case or enclosure. The small circuit board in the back left is the iBOB2.
    Hope this helps,
    Iron-Man
  1. Need help getting electronics going
    By Dman65 in forum DIY CNC Router Table Machines
    Last Post: 09-11-2011, 12:41 PM
  2. Electronics...
    By Stiggero in forum DIY CNC Router Table Machines
    Last Post: 01-22-2010, 12:12 AM
  3. DIY CNC Electronics
    By Paul_P in forum CNC Machine Related Electronics
    Last Post: 12-25-2009, 08:15 PM
  4. I need to know everything about CNC Electronics
    By alanfreefall in forum Servo Motors / Drives
    Last Post: 07-19-2007, 02:56 PM
