Hello, I am new to laser engraving and looking for a machine that can engrave the belly of a large bourbon barrel. I can only seem to find machines that do smaller flat surfaces and a barrel is too large to feed through. Any suggestions??
mount a 4th axis under a normal flat laser and have it on a arm that rides up and down so you can keep the correct focal length... I don`t think there would be any cheap off the shelf machines that well do what you want ,, should be easy to build ,, if you need a better idea of what I am thinking send me a IM
