586,082 active members*
3,650 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Need A2100 software for arrow 1000
Results 1 to 9 of 9
    Oct 2008
    16
    my drive has gone bad, machine is down, and i would like to upgrade to an IDE flash drive with a new copy of the control software. the problem is i need the software. can anyone in cnc-la-la-land please help?
    Dec 2006
    584
    Re: Need A2100 software for arrow 1000
    You can contact FIVES company at 800-934-0735 and order the windows NT 4.0 service pack 6 with the MAI and the M!Y.**** file. You may need help with the install and setup of the machine. DID YOU BACK UP ALL OF YOUR FILES PRIOR TO THE HARD DRIVE CRASH ???? Give us a call.
    Mike http:// cncmachineservices.com
    Oct 2008
    16
    i have found a backup of the software! can you advise how to properly convert from an IDE hard drive to a compact flash solid state drive?
    Jun 2004
    511
    I have had good luck with the Logicube OmniClone 5 U industrial grade hard drive duplicator.
    Ebay has them.
    Oct 2008
    16
    I am interested in hardware specifics. is there a certain type of compact flash card to use for best results? what are the flash card capacity limitations that the control pc will recognize? what about the IDE to compact flash adaptor? is there a best brand or type?
    i have seen a seller online who is selling these setups but i am poor and would like to configure my own to pinch some pennies.
    Jun 2004
    511
    2 Gig seems to work best. I used solid state hard drives, not flash cards. The adapters are hit and miss. Best is an IDE SSHD.
    Oct 2008
    16
    ifixcnc, do you know what capacities the acramatic control pc will recognize? isn't there a limit to how large a drive you can connect to them? I am curious why do you say 2gb works best? have you had problems with a 1gb? I like your recommendation of an ide drive instead of a flash card.
    Jun 2004
    511
    2gb or under is fine. I find the 2gb are easy to find and work well.
    Jun 2017
    Sorry for posting in this old topic, has someone a backup of acramatic 2100 for arrow 750?
    Inviato dal mio GT-N7100 utilizzando Tapatalk
  1. Cincinnati Milacron Arrow 1000 A2100 - relocated - HELP!
    By veggiedawg in forum Cincinnati CNC
    Last Post: 11-17-2022, 03:00 PM
  2. Cincinnati arrow 1000 A2100 - having problem alignment
    By JFYM88 in forum North America RFQ's
    Last Post: 06-03-2017, 03:47 PM
  3. Arrow 500 with A2100 cnc
    By rai in forum Cincinnati CNC
    Last Post: 07-26-2011, 11:54 PM
  4. A2100 Arrow 500 Error help
    By kentsui in forum Cincinnati CNC
    Last Post: 10-31-2010, 06:44 PM
  5. A2100 - Arrow 1000: Operating System Lost
    By JTG2003 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2010, 04:33 AM
