586,069 active members*
3,402 visitors online*
    Nov 2013
    78
    Doosan 2600 lm c axis
    Need help with a program to m/c a square the af is 36 mm and there is a 3mm radius around the corners the square is on the front of part and the bar diameter is 51mm I need tool comp and I think polar mill is what I need any programming examples will be greatly appreciate also I will be using an end mill to profile around part thanks.
    Using Tapatalk
    Jul 2005
    380
    Re: Doosan 2600 lm c axis
    G12.1 will do the trick and G41/G42 works supremely well with it!
    Just sent our in-house manual to you!
    Let me know!
    -Doug
  1. Replies: 3
    Last Post: 04-22-2020, 04:39 AM
  2. BP Series 1, 2HP Rigid Ram. RPM max only 2600. Otherwise perfect. ???
    By cnc1000 in forum Bridgeport / Hardinge Mills
    Last Post: 11-27-2014, 08:07 AM
  3. Doosan 2000sy B axis locked up
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-01-2014, 08:45 PM
  4. Puma 2600 w/31i control and LNS Sprint 565
    By GreggC in forum Daewoo/Doosan
    Last Post: 01-12-2014, 04:34 PM
  5. doosan s310sml b axis trouble! help!
    By bluetooth_1989 in forum MetalWork Discussion
    Last Post: 10-06-2011, 05:46 PM
