586,106 active members*
3,127 visitors online*
    Apr 2013
    31
    NEED HELP: ROMI CENTUR 35E
    ROMI/BRIDGEPORT 35 ALARM -GEAR OUT POSITION HOW DO I RESET TO CLEAR THE ALARM
    THANKS,
    JIM
    Got it figured out, if anyone else has
    this problem, contact me.
    Jim
    Jun 2014
    10
    Re: NEED HELP: ROMI CENTUR 35E
    hello, arrive late to respond, certainly had problems with the pneumatic cylinder, that system often fails to time.
    regards
    Jul 2017
    Quote Originally Posted by jschmid View Post
    THANKS,
    JIM
    Jim
    Jim,
    My lathe is locked up right now and displays the gear out of position alarm. What did you do to clear the alarm?
    Jim
    Jun 2014
    10
    Quote Originally Posted by JamesButler View Post
    Jim,
    Jim
    Good morning,
    if you still with the problem, try to locate the engine of change range, uncover it, clean it and lubricate it, forcing manually the change.
    The change is automatic? or via a "M" function
    Good morning, if you still could not suppress your problem, try to locate the engine of change of range, uncover it, clean it and lubricate it, forzandolo manually the change.
  1. Roni Centur 35E Stuck in Feed Hold
    By amphib in forum Bridgeport / Romi Lathes
    Last Post: 11-01-2014, 02:08 AM
  2. Romi/Bridgeport Centur 35 lathe
    By jschmid in forum Bridgeport / Romi Lathes
    Last Post: 03-24-2014, 07:05 PM
  3. Romi Centur 35E Lathe
    Last Post: 06-04-2013, 03:20 AM
  4. bridgeport romi centur 35 e 090 P/S alarm
    By sdconcepts in forum Bridgeport / Romi Lathes
    Last Post: 03-06-2013, 05:04 PM
  5. Romi M27 Help!
    By Shadetree in forum Bridgeport / Romi Lathes
    Last Post: 04-18-2010, 07:24 PM
