I need to make some holes in zx e yz faces and my post does not give me the right code
i have 2 post processors but neither of which do the right code
I send the post processors
Could you please send me also Alphacam file? Do you know how was the look right NC code which must generate this post?
Try the 2 attached Posts I modified from your originals to see if either of them work, The code I generated in AlphaCam from these 2 Posts looks correct. Just remove the .txt extension
Regards,
Hi Frank would you have a post processor for Mastercam Osai 10. I have been unable to find anything. I bought a used Cr Onsrud router and need to get it working. Thanks Kevin
